VHT makes hi-temp engine enamel rated to 550 degrees F (288 degrees C)
Direction 1/7 says, "Clean surface thoroughly. Remove grease, oil, loose paint, rust etc. Sand previously painted surfaces lightly, then clean with a high grade solvent and allow to dry before spraying"
No mention is made of undercoating.
This product is used on engines - and I used it on an Alfa Romeo with pleasing results.
Honestly, Mine is done with $12 cans of touch up spray paint from super cheap. Its been 6 months and it still looks like this:
No its not as good as ceramic coating or any of that, but its stood up to the heat fine. Its not even prepped that well cause it has scratched off in one or two spots, but the heat is not a concern. I have 2 spare sets of cam covers to do it properly later on, but I'm pretty happy with how well these have lasted so far
I'm not sure what sort of position you're in with your cover being on or off, but if you sandblast, chromate etch and then paint....it's going nowhere fast. 3M have a nice acrylic clear that polishes up pretty well, other than that, all of my cooler pipes under the bonnet were a nice decent coat of polyurethane that looked wet it was so glossy.
vht make an engine clear temp rated to 550 degrees, did my covers using leftover calipers paint and this clear. looks shinny and hasn't gotten damaged at all by heat
To get a shiny look, just get gloss.
...not semi or satin or matt
I'm not sure about a Hi-Temp Clear; but gloss is quite shiny.
Any Automotive Paint shop can advise.
Did my r31 rocker in gloss red 11 years ago in brake caliper paint , still perfect
R34 is done in metallic titanium silver ( not high temp) coated in anodized blue colour cast ( not high temp ) and high temp vht clear , looks amazing and way better then powder coat , under 50 bucks just prep well and dry in warm dry air and heat up a bit a few times before mounting to set the paint ( hi temp clear will cloud if you dont)
I did my brakes and rotors same process 4 years ago and they look perfect still )
Yes the humidity for most clear coats should be 40-60% tops but its even more critical with that vht clear and the ceramic paints from vht wont set until heat cycled a few times ( sunlight or heater and 23c at least when sprayed , the paint and alloy must be warm or the alloy repels the paint from being cold ) ) they look dry but easy to fark up , that clear and ceramic paints fark up paint that isnt 90% dry at least before applying
The ceramic matte black is amazing stuff it bonds well to clean degreased metal and does cool to the touch a bit , works a treat to stealth stainless mufflers that stand out otherwise
But use care it must be applied with carbon mask at least , its really harsh when spraying
i didnt pre prime any metal except degrease light sanding and wax and grease remover and it wont come off and holds up to tools hitting it , i used the titanium silver instead of the silver base coat on metal cast it really pops a lot better in sunlight with blue candy over it , and the colour alone looks damn nice , rustolium brand only ( crappy sprayers lol ) but close to 2 pac custom look
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
