hi guys, im just wondering if it can be done, the car has alot of work and the 3/4 clutch has given up.
its running a power FC ecu, i know it can be bolted up, but will i need a different tailshaft/yoke and the main concern is the gearboxes ecu. not sure wether mine has been modded, but id say so to be running with the PowerFC, the ecu was in the car when i bought it.
cheers.
p.s would most likely put in a fully manualised KEAS valvebody aswell before bolting it up
Edited by OMY31T
https://www.sau.com.au/forums/topic/401178-r34-auto-into-r33-is-it-possible/
I'm not going to say categorically yes or no......but......The R33 auto has a separate TCU in its own box. The R34 auto has the TCU as a little board as part of the ECU. The R34 auto is also tiptronic stylez, so the way it is controlled is different (ie, the switchgar it expects to see as inputs).
Also, isn't there some deal where you can't put a PowerFC into an auto R34 because of the location of the TCU as above? Meaning, the best tranny to use for such a purpose would probably be an R33 auto anyway.
Not going to be easy. Sounds like a headf**k. I wouldn't contemplate it. Why would you go to an auto anyway?
the car is already auto, and has been setup for it... and yeah i figued thiswas the case i just wanted some oher opinions, im also to believe the tiptroic is a weaker box aswell, i just had someone offer me one with 36,000mon it for $250 haha cheap box to rebuild, but iguess ill have to hunt out a decent r33 box.
yeah, im trying to get out of it without haveing to do a full rebuild atm. ive had it all costed out and to rebuild for 700rwhp, im looking at around $5k incl a stall converter. pretty good price, but just a bit hi for me to fund it right now, and need the car running.
Edited by OMY31T
  • 4 weeks later...
Not true if it's a non-turbo. ECU and TCU are still separate for non-turbo R34.
are they both re4s? check all the elctrical connections you'll prob find they're the same but r34 has different plug setup so would have to chop and change wiring, if they're not both re4s don't go there!
with a manualised valve body so no electrical issues should be doable?
Edited by WMDC35
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
