Hi guys,
So ive just bought an r32 (coz i love the shape) but want to drop a rb25 in it.. I want to run about 350-400rwhp and want it to be street legal to id have to do the permits etc..
Ive never attempted such project before so I need a bit of help/advice - better safe than sorry.
The mods I was thinking of having the following upgraded:
Turbo
Injectors
Fuel pump
ECU + tune
FMIC
6-9 puck HD clutch
Now here are my questions:
1) I been hearing a lot about the Gt35r turbos but unsure if theyll do or bit expensive and might as well go with cheaper?
2) 440cc or too low?
3) a lot use Walbro is there a specific pump needed or mainly all walbros are high flow rate?
4) what difference between ECU + tune or just a nistune (daughter board) + tune??
5) how will 6 or 9 puck clutches differ?
6) would i need a GTR gearbox or would stock do?
7) what would engineers certificates cost roughly? and engineers cert is done after all the upgrades? or before?
8) would i need aftermarket pistons/conrods? (ie forged)
8) have i missed anything? ie would i need an aftermarket suspension system to handle power/thrust? if so, i like a smooth ride (not rough) any recommendations?
and finally, how much will all this cost? roughly between what two figures?
MANNNNY THANKS
Edited by v8 eater
https://www.sau.com.au/forums/topic/401181-need-advice-for-my-build/
all these questions have been answered before with various opinions as well, have a read of the dyno thread for what power mods you'll need, 35r is too big, walbro not my preference...
As for cost read through the countless other threads titled 'need some advice' or similar, people all seem to ask the same questions, at the end of it if you need to ask, you need to learn by reading and researching.
400rwhp you dont need a forged 25
35r is too big
Authentic bosch 040 fuel pump preferred (larger for E85)
500cc+ injectors, (750cc+ for E85)
Get a full ECU like vipec, link G4 or Haltech
Have fun getting a engineers cert..
someone else will come in and say nah the 35r will be fine, nah the walbro will be fine, nah the nistune will be fine etc...
and then you'll still be left with no direct answer and probably still buy the wrong the parts for 'your' pref and application
i'd do a 25neo + some form of 25 box (some ppl keep the 20 box but thats asking for trouble, plus you can sell the whole 20det and box as package to the s-chassis guys)
then
highflow stock turbo/hypergear's big turbo with stock front housing (looks stock and still runs an internal wastegate
or
cheapy NZ manifold + kando t67 + 40-50mm wastegate
one will keep a stock look, one won't look anything like it, both should get near your goals
then for the neo motor, get some id1000's (reportedly run really well and can still give you good economy but will give you ability to run e85)
z32
nistune the neo ecu (make sure you keep vct!!!)
personally, ill be running one of these when i eventually get round to it http://www.deatschwerks.com/dw300-fuel-pump-tech/
either turbo should get you up around the 300kw mark, maybe even 350kw on e85
I think most of you guys dont even bother reading my questions lol.. I have been to the link a few of you mentioned and got a lot of ideas which is why im posted to clarify some points.. ie: cost/difference between 2 items etc.. if someone can address my questions point by point itll be great.. its ok if you miss a or skip points which you can not answer.. thank for your input guys, very helpful!
"what would engineers certificates cost roughly? and engineers cert is done after all the upgrades? or before?"
You should really go and talk to your chosen engineer first as he will have to dictate what you can and can't get away with. Otherwise you can do what most of us (down here) have done and try to make a stealth stock looking setup you can get away with on the street.
Thanks Scotty,
So i read @"highflow stock turbo/hypergear's big turbo with stock front housing (looks stock and still runs an internal wastegate"
and hes referring to the stock turbo - so i go to Xspeed for example and ask them to high-flow my turbo?
So fitting a big turbo in a stock housing is called hypergearing? also where can i get big turbo with stock front housing? who would do it? and how would a bigger turbo fit a small housing?
Thanks Scotty,
Getting Xspeed to high flow your turbo will go to gcg and cost 1800 for maybe 230-240kw. Contacting hypergear who is on here will do it much cheaper and more power.Prob not as much power as you were hoping for but. Check the hypergear thread. Should keep you busy for a while :)
Hypergear is a company that highflows and supplies affordable turbos in Australia.
HKS is company that builds great turbos and so does Garrett
You have so much to read and learn, all the info is either on this forum or on the net, how is it you need to be spoon fed?
Not trying to be rude (though it may come across harsh) but the knowledge is all here, you just need to take some time and read.
You only joined the forum 6months ago, I joined years ago and have been learning ever since...
I rarely have to ask any questions, because its all here I just search and read.
lol yes you can call it that way :P .
Normally just send in your stock turbo, we will produce a new core with bigger and steel made wheels, then machine your factory housings to suit it. So you get back a brand new turbo hypergeared into factory housings.
Realistically this is impossible. 400hp calls for fmic, 3" exhaust, pod, etc which (depending what state your in) are not 'street legal' in the eyes of the po-po.
You have a lot to read, an engine conversion is a difficult & expensive process (I'm 3/4 way through an awd rb25 install into my r32 gts4) & even if you have the knowledge, time & money it can still very quickly become a head ache.
Clutch- worry about that after you've decided which path your going down.
I wouldn't bother engineering. Keep everything in the engine bay low, black and quiet, and don't drive like a wanker and you'll be sweet ;)
If i was you, & your rb20 is still running, I'd do this;
Keep rb20 & box. (if my rb20 was still running I would have done this)
- td06 20g turbo
-gtr injectors & pump
-z32 afm & nistune ecu + good ebc
- e85 fuel (depending on availability?)
As well as your run of the mill mods like fmic, pod, 3" exhaust, 16-18psi etc. this should set you up for 220-240rwkw which is pretty much the limit for a 20+ yr old unopened rb20.
If your dead set on a 25, I'd find a rb25neo (r34) engine & box package &:
Gt3071 / gt3076 turbo on 15-18psi
1000cc injectors, walbro 400lph intank pump & e85
Nistune/pfc/haltec - whatever your tuner prefers
Yellow jacket coilpacks
Tomei 256 cams & cam gears
Z32 afm, fmic, pod, 3" exhaust etc
That's what I'm doing with my rb25 in my 32 & will hopefully see me on 300awkw (400hp). Have a look at my thread in forced induction & have a read.
- remember anything with cars, take idea in your head, double the time & double the money & you have your realistic answer.
Thanks everyone.. Hyper gear, I will be considering it :)
thanks josh :) sort of what i wanted to know :)
but one more thing, im a bit confused with e85.. thats a methanol fuel and is rare at local pumps but what sort of setup i need to run e85?
1000id and an ecu tune? thats all?
wow there's already a few threads to cover your last question... one is particularly long and full of info...
but you've already that, right? RIGHT?
nah you didnt, you havnt read or researched much at all have you...
the people answering your questions will eventually get sick of answering the same ol questions time and time again,
such as I am apparantly.
e85 is ethanol (85%)
you can just get bigger injectors and a tune but ideally you'd run an ethanol content sensor and an ecu that can read it (most $1500+ ecu i think)
this will let you put 98 or e85 in and it will adjust to suit otherwise you will probably hit detonation if you ran 98 on your e85 tune
if u want more precise answers and prices find out whos your closest performance shop/tuner,..
give them a call and they should be able to answer all your questions at once...
if looking though the couple(by this i actually mean 100s) of threads on sau cant answer ur questions then I hope you get some very patient tuner..
its not just a matter of bolting on parts and ul get the power..
if you are asking these questions you probably will be getting someone else to do all the job for you so you need to also consider labour costs..
well theres my recomendations anyway..
  1. A GT3076R will do
  2. 600cc or more (850cc for e85)
  3. Bosch 040 pump will be perfect (x2 for e85)
  4. Get a pfc or nistune
  5. Clutch will depend on what ul use it for
  6. Standard should do
  7. Speak to an engineer
  8. A standard 25 won’t hold over 280rwkw if used on track for too long but will last a bit for street use
  9. Exhaust, z32 afm, coilpacks, intercooler, radiator(if tracking), boost controller, labour.
  2. 600cc or more
mate if you dont wanna help, its as simple as not coming back to the same thread which "made you sick". I hate tossers like u who use complaining as a tool to show off that you know shit. Humble yourself please, kthxbye.
Herb and Tom thanks heaps for the info!
  • 600cc or more (850cc for e85)
  • Bosch 040 pump will be perfect (x2 for e85)
and
Whats that feature called? just ethanol sensor support or its got a specific name?
also how does it know when you switched from ethanol to 98? different tanks and a specific way of switching?
and yes, the work will be done by certified mechanic not myself.. its a shame that im doing Mechanical engineering third year and barely know how most of these things work.. I cant wait till i put this crap we learn into practice lol stupid uni -.-
extras: z32 afm, coilpacks and a boost controller
thanks herb, how silly, i forgot about these. :)
with the coilpacks, something like the splitfires should do? or is there a more heavy duty type id need?
z32 afm = 300zx twin turbo air flow meter?
also, electronic boost controllers r always better?
many thanks again
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
