hey this is my daily driven r32 skyline am either looking for swaps for an s13 sr20det or kool turbo corolla or something of interest can lower price on car by minusing some suspension parts, GTR wheels are not for sale and will not come with car. stock wheels supplied
engine:
rb20det
front facing plenum
xf throttle body
gtr injectors
fmic
walboro 500hp pump
sard fuel pressure reg
haltech e6k
haltech coils
haltech igniter
haltech 3 bar map sensor
T34 garret bran new turbo 550hp rated
highmount stainless exhaust manifold
48mm nitto external gate
3inch exhaust zetti muffler onto twin 3 inch pipes
adaption made for unscrewable cap to have screamer on track or plumbed in for road use
60mm twin core alloy radiator
all new gaskets and seals throughout car.
gates racing timing belt
new plugs
oil changes every 5000km
drivetrain:
rb20det gearbox shifts nice no crunchs
6 puck solid centre clutch with heavy duty pressure plate
billet lightened flywheel
stock diff shymed within reason so its not noisey in a car park still clunks a bit but not noticable
suspension:
bran new super street tein coilovers
r33 front lcas
extra lock heavy duty rack ends
pillow jointed ikeya formula copy tie rod ends
adjustable rose jointed castor arms
has just had full wheel alignment to drift and drive as daily
handbrake has drift button
body:
body is rough has been spray canned matt black.........
will be sold with stock wheels in black. gtr wheels not for sale.
full vertex bodykit
has boost gauge
car makes 351.7hp at 18psi dyno sheets to prove is fully safe tuned is running stock timing with some extra boost so will last forever being the ol reliable rb20
car is my daily driver have spent countless hours getting the car to where it is now, want an s13 or s14 shoot me your offers must be turbo.i have prolli missed some things is registered etc any info or pics needed let me know via txt or call am not on the pc very often to please contact via mobile cheers
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
