so my R32 GT-R developed a light load metallic rattling sound a few months ago, i drove it occasionally knowing i'd most likely be up for a new engine soon. the time has come. the sound is bottom end and getting louder and deeper :(
it's a 1989 gt-r so i was wanting to upgrade to at least a late model rb26 for the better oil pump drive gear and just wondering what problems i will come across. if i go late model 32 gtr engine, will the early push type clutch gearbox bolt up the same? what if i ended up finding an r33 gtr engine? will i have problems then?
if i upgrade to a late model 32 or 33 engine, will my ecu be fine? or will i need the r33 ecu if i upgrade to a 33 engine?
are there any known hassles in this department of changing to a later model motor? is it best to just rebuild mine? (nearly a 3rd year apprentice mechanic and would love the challenge but it's not beneficial if the late model upgrade is worth it)
if i go an r33 engine, is the front diff the same? or will i need to swap the internals from my diff to the new sump? or just swap the whole sump over?
any help you can offer would be great!!
álso, any reccomendations on where to buy a new engine from that i can trust will be good? or should i consider buying a new bottom end only and swapping my head over? if that's a better option, will my head be compatible with all model rb26 bottom ends?
https://www.sau.com.au/forums/topic/401238-need-a-new-rb26-few-questions/
the long motors are all the same, in fact I just put a 33 motor in my 32.
You will have to watch out for diff ratio and CAS if you use a 34 motor, and some wiring differences if you use a 33 or 34 motor. In either case just swap across the gear from your 32 motor.
Assuming it has a f**ked bearing, do not re-use anything from the old motor that had oil in it. Or if you feel brave, stuff like the turbo oil feed and return, and the turbo cores themselves may be useable with a really good clean (probably not). Never ever reuse the oil/water interchanger under the oil filter, you will never get the inside of the oil part clean.
thanks for the reply. i put two brand new turbos on in november and haven't driven it more than 2 thousand k's i reckon so i'll definitely be swapping the near new gt2860 -7 turbos over to the new motor. the bearing noise is still quiet, it certainly hasn't actually let go yet so providing i pull the motor out before it gets much worse there will be no problems with them. but also, hadn't really thought about that side of things so i will be making sure my turbos are not contaminated before i install them on the next motor. how did yours go? the 33 motor easy to swap to?
yeah there were no issues, everything bolted over fine. Just lots to do.
BTW, mine had a spun big end bearing, no knock at idle, only when revving. it looked like tinsel inside the sump. you would never believe where bearing material can get to.....
I have also lost the turbos 100% of the time I have re-used them from a motor with a spun bearing within a few thousand klm. These turbos I cleaned out like crazy, as best I could without disassembling, and they have been OK for 500klm so far. Still far to early to call it a success though. Also, I changed the oil and filter after 50 and 500klm as well. You can't be too cautious when the turbs are worth 1500+ to rebuild
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
