Whats This Mean? Blown Head ?
My mate once bought an rb25 of someone and it had wasp nests in the intake ports like yours
Sounds like it had extra killawasps :)
It's not an old rag is it? Pretty wild colour
nah its not a rag lol, theres other crystallized looking stuff of the same colour in the thermostat housing, which is why i thought gasket would be f**ked, could it be pink coolant sludge?
I know when I worked for ford a lot of the older models had that pink coolant crap and leaks did chrystalize like that... If its the same as the stuff on your thermostat housing and the coolant is was pink then you've probably answered your own question... I'd be investigating further as its hard to guess from a single pic... What did the intake gasket look like?
Ow wow, now i am on a PC that pic looks gross! :P But if there is pink in the cooling system then its probably coolant, and if there is coolant there its probably not good news....
This looks alot like an anti corrosion and coolant additive called Nalco which we use on all our Caterpillar and other large and small gas engine that I work on. When it leaks it crystalises very similar to this and is a very similar funky pink colour.
If you get the dosage wrong it can destroy waterpump seals from memory its ratio is around 1litre of treatment per 50 litres of water, Most of the engine I work on hold around 1000litres of coolant so a 20litre drum does it just fine. When mixed correctly though it should be a very pale pink colour almost barely visible.
Maybe its isn't the same stuff thats in your engine but as i said it looks very similar colour and seems to cystalise similar to it.Perhaps pull off the water pump to see if there are any other traces of it in there.
Good luck
Edited by rb2534
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
