Im running around 90 psi or 6 bar at around 6000rpm, Im wondering if this may be causing some of my oil problems, Ive read that some are running 70 psi, Im able to lower my oil pressure by a bleed system and Im wondering what would be the best/safest psi to run..
What oil pressures are you guys/girls running.
Thanks, Mark
Depends on your oil type, weight, crank clearance etc, im running 2.5 thou journal clearance and redline 15w/50 with pump (tomei) at 65 (more like 70) psi.
What pump are you using?
Tomei pump 10 - 40 oil in a newish (5000k) motor
Thanks, Mark
Lucky, no need to take motor out to adjust it :-)
In my opinion, provided your not making alot over 300-350 kw 70 psi will be ok,
Double check this, i may be incorrect.
Oh and is it an ester synthetic oil or cheaper synthetic?
making 350 on low boost and about 380 on high ATM, the oil is Nulon.
Thanks, Mark
Ok thats a shit of a lot of power lol. 90 is alright imo.
Food for thought is v8's that typically have 5 main journals that are usually similar size to an rb which has 7.. and most run 60 ish psi with average oil.
And for similar outputs it works perfectly for alot of them.
I may look at getting a lighter synth oil (for drainage), and knocking the oil pressure down to about 80 psi, .
I need to do something to slow the volume oil getting into the head.
Thanks for the info, Mark
lighter will increase the amount in your head, i found this before fitting restrictors etc when i had an n1 pump, lighter atomises and blows out easier, also more will get to the head and so on... I learned it wont help lol.
Nothing is ever easy is it, what weight oil you using now ?
Thanks, Mark
You're fixing the wrong thing
Fix the breathing problem your engine has, not the oil pumping thing it's supposed to do
That statement is more incorrect than 10 incorrect things
Leak down was good, I cannot remember reading but it was apparently OK, head drains were drilled out, has - 12 head drains/vents to sump, has - 12 return from catch can to sump, has 1 x 0.8mm restrictor for the head feed, 1 x 0.6mm for the VCT.
The motor was pulled and tolerances double checked.
Its fine at the drags, the only time it isnt is when Im getting up it hard and going around corners.
I dont know what else to do, my brain hurts bad..
Like I said, I found this on my engine originally. Between running 5w/30 and 10w/60, the lighter was an absolute oil spewing mess, the thicker pumped some out but nothing like the 5w/30. So how do you figure this?
Im not saying its the solution by any means, but thats what I personally experienced so my statement stands.
More specifically this
Ok, it seemed to blow out more as oil in vapour and paint the whole engine bay, well, how i see it anyways, that was the 5w/30 (all edge sport) then the 0w/40 was a tiny bit thicker and sorta ran out more than spray and then 10w/60 used to just dribble a bit.. Thats how I came to such a conclusion
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
