Hey everyone, I have a 32 gtst m spec with the 4 pot brakes and 2 pot rear!! I am looking to do a brake upgrade.. So I did some research and have found I can put a adapter in and run a bigger rotor, but I am alittle confused if I can do it with these calipers!! And I also want to no if the adapter brings the caliper out towards the inside of the rim, because I have a bee's dick Clearence as it is!! I am also worried about caliper to rim Clearance!!
Thanks is advanced!!
https://www.sau.com.au/forums/topic/401264-brake-upgrade-confusion/
There are adapters to suit the R32 calipers to convert from a 280mm disc (R32 size) out to a variety of common sizes, including the 324mm Brembo Skyline disc size. If they are made right, then the caliper stays centred on the disc and does not change position. Only moves outward radially.
Personally, I would rather get some R33 calipers as a basis, as the R32 calipers are flexy and groany (by comparison). The R33 are stiffer. Then you need different adapters, because R33 calipers have longer legs.
Do a search. This has been covered 40 gazillion times.
sorry for thread jacking, but i have a 32 gts 4 and fancy going for a brake upgrade.
I'm wanting to keep the car for road use, but want to get the weight down everywhere i can.
So,
Floating discs for an r33 gtr:
http://www.ebay.co.u...=item2a15729775
What parts do i need from a 33gtr?
Those(or similar)
Calipers
Carriers (Brackets)
Pads
Brake lines?(or are they the same)
And would these be any heavier, bare in mind the discs should be lighter?
Also will they fit under 17's
Any help would be greatly appreciated
For reference:
Brake sizes
http://www.jdmlegion.com/KnowledgeBase/Brakes/Nissan-Skyline-brake-disc-and-caliper-information-33633030-5ca2-4f69-b247-5cb9366bcaf1
Edited by sev
To suit that rotor you neither either:
A: The R33 GTR caliper (that is all), or the R32 GTR Brembo caliper - same same.
B: Use the GKTech adapters with the R32 gtst sumitomo calipers.
You cannot use the R33 GTST caliper unless you use different adapters (Unique auto sports).
I would not buy those eBay rotors as there is no indication who manufactured the disc or the hat. Therefore they could be yum cha made from recycled cardboard. The DBA 4000 ones would be first choice. I wouldn't even get slotted rotors if I could avoid it.
Can't tell you if you'd need different lines, but it is possible.
Im not sure what the cost of a pair of brembo calipers are, but it seems false economy to buy the adapters. Surely you could sell the sumitomo's and recoup some of the expense of the brembo's. For less than $116 for the adapters. According to the link, the brembo's have a bigger piston area, and i'd imagine they are easier on the eye.
Thanks for you're help
GTSBoy yeah i noticed afterwards looking back on them. For some reason i thought they were AP's :domokun:
A set of 2nd hand set Brembo's, front and rear go from around $1800.
You could sell a set of Skyline Sumitomo's (turbo model) anywhere from $150 - $250.
Yes, Brembo's have larger piston area.
Those rotor adapters are just so you can run a 324mm (Brembo) size rotor but still keep your stock calipers.
Running bigger rotors will allow a higher heat range so your brakes do not over heat as quickly.
Oh wow i didnt think the brembo's and the sumi's would vary in price that much.
I'm still on pom prices.
Undecided now.
Thanks for your help.
Yeah, just have a look at the For Sale section.
The price differences are quite a bit.
If you fancy a brake upgrade, start with:
New brake pads / Slotted rotors / HEL Metal Braided Brake Lines / Brake Master Cylinder Stopper.
If you still want Brembo Calipers, I believe the R32 GTR V-Spec / V-Spec II and R33 GTR calipers are all interchangeable.
Re-build the calipers and do what I listed above, but obviously buy the Pads and Rotors for Brembo size calipers.
Yes prices are in AUS Dollars :)
The question is on what grounds have you decided you want/need a brake upgrade?
If its performance then what is the current problem you are experiencing. If its part fashion/aesthetics (not having a shit, its part of the reason why I like big brakes) then its hard to go past the bracket and rotor upgrade with some nice performance street pads.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
