Hi,
I have been doing a bit of research on EWPs and can find plenty of info but not so much real world testing. Does anyone here run an EWP?
Was there a notable difference in cooling efficiency and does anyone have a dyno reading as to how much gain can be made. (hp gain is secondary, just curious to see what the real difference is)
Cheers in advance.
https://www.sau.com.au/forums/topic/401303-electric-water-pump-benefits/
From a mate's experience in his old Merc with an electric fan combo.
- Great for heavy traffic in summer.
- Engine slightly more responsive.
- Heater doesn't seem to work as effective - Takes ages for the heater to warm up.
- Less heat soak, pump continues running for a few minutes after engine is turned off.
- Controller had some gremlins after working flawless for a year:
- pump did not turn on once - nearly cooked his engine.
- pump never shut off when he turned off the engine - ended up with a flat battery.
I'd go for one myself. able to slow and speed up water flow depending on temp and working electric fans from the same controller (like a Davies Craig) could allow fast warm up and constant temperature control.
When I get some money up I will buy and test this, but for the moment will stick with the old crank driven pump, only because it still works :)
