Hi guys, a friend was driving his r32 gtr when a sudden rattling started. We assumed it was bottom end and proceeded to replace the bearings which didn't look too bad which posed a few questions when we put it back together. Upon first crank over the noise was still there so we split the head and block
Inside cylinders 5&6 were bits of metal and stuck on top of the combustion chamber. So checking the turbos there was no visible sign of pieces missing thus far
So where could the shards come from in terms of the intake as two cylinders had the metal inside?
Car is 90 model Nismo edition and is stock apart from ball bearing turbos
I will post pics tomorrow
Thanks!
https://www.sau.com.au/forums/topic/401347-metal-in-combustion-chamber/
Valves and seats look fine, the damage is only on the sides where the piston gets the closest to crunch the metel into the head. We also pulled the pistons out to check possibility of a ring letting go and somehow being sucked through the intake to the other cylinder but they were fine as well. Spent today also looking for any gizmos on the way through intake from the intercooler on and checking for bits of broken metal within etc. The bits that came out do look some sort of ring or washer.
So tomorrow will entail stripping the head apart, sending it away to get it checked for any possibility of something wrong and checking the turbos in more detail along with the intercooler in case anything could be still lodged assuming its come through the intake. Otherwise has to be put down to debris, but surely something must of let go.
Really blind to what the problem is.....
have you checked the tips of the sparkplugs?
Yes we did before spliting the engine, the plan was to send a camera through the spark plug hole to see what was going on. In any case it was one of the first things that we had a look at but they are all in tact. If not anything like that, it might have to be said something has fallen or was placed somewhere along the intake during a previous service or something and has finally made its way into the cylinder. The car was breaking down at boost when warm before this but I cant this being a cause of that.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
