Hi all
Getting the good old 100k service soon and thought to myself let's beef up that mid range a little.
We're talking -9's with the basics
My sig tells all.
Now my afms maxed out, but I feel that it should be fine unless I want to go over 300kw.
Basically at the time of the 100k service I was thinking of throwing on some adjustable cam gears and tune adjusted.
Will it be fine you reckon?
Or should I just pull my finger out and call my tuner? Haha.
https://www.sau.com.au/forums/topic/401374-lets-talk-mid-range/
+1 CAM GEARS
my old gtr setup with -7's had the cam gears tuned for midrange rather than outright power, certinaly felt good to drive on the street, especialy around the twisties like nato park etc
im an idiot for not putting cam gears in my new gtr, so im doing that very soon to beef up the midrange aswell
Drop in Tomei type B cams. Add cam gears. If you're thinking about more changes later, may as well throw in an ECU with Map and then not need the AFM's anymore.
Or, the non budget option; stroker motor time.
Lol, I know I want to :S. so exxy
I believe there are a few NISMO AFMs for sale 2nd hand in the for sale section
Straight plug and play with the Nismos, I have Z32s in mine and there is a little caressing to get them in and new plugs ofcourse
which reminds me, i still have my Nismo AFM's ... should probably get around to selling those :D
or you could go MAP sensor - do the numbers on selling AFM's and Power FC, you might find the Link G4(you're Unigroup so i'm going Link) is not much extra at the end of the day
You sound like a broken record. You say that so much :D:P
haha, you guys.
Lets crunch some numbers
Nismo afms - US$800 + tune up
SELL
Powerfc - $750
AFMS - $300 (would keep afms for stock air box purposes)
--------------------> $1050 $750
BUY
Powerfc Djetro - $1000
whole new tune + installation - $800 - $1000
-------------------------------------------------------------> $1800
$1800 -
$750
$1100...... extra - tune up. So lets say $800
Or $800 for afms.
Shit, haha. I think Ill just be that looser guy not running map
Edited by Hadouken
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
