I had a rattle in my stock R33 S1 steering wheel for about 6mths, then 1 day as I turned into a driveway it started going off. From then on, everytime I turned my steering wheel to half-lock it would trigger the horn.
If you have an airbag wheel you will need to go to an Import specialist to remove the airbag and fix the contacts.
The rattle is the white plastic horn button inside the steering wheel shattering into pieces due to age. Open up your wheel and its centre pieces, try go get all the pieces back and glue them with supa glue and some magic tape to hold them together, that will do the job.
thanks guys, there is a rattling in there so i should check it out, but i aint gonna do it myself cos it has an airbag, dont want that shit goin off prematurely.
i have an alarm, its a mongoose one so that could be it, but ill take into an airbag specialist.
anyone know of any good ones in melbourne??
my horn went off in the middle of the night n woke my whole court up, got in the car and pressed the horn and it stopped... the next morning I took off my steering wheel to find a bug inside pretty much dead (still twitching a little shortin the contacts) Must've squished it when I pressed the horn... farken thing....
rs73, its a bit more complicated then that, you have capacitors that store charge (if you have an acco, you need a charge to set the bags off - so if you battery leads are chopped off the bag has still gotta deploy), Some cars you have to unplug it at the module, some let you unplug it at the wheel.... but its up to you
Sumo
P.S. how are you gunna test the horn if you dont have the battery hooked up?
Easy! Before you test the horn, reconnect the battery.
I was talking about disconnecting the battery only whille opening the steering wheel just to check if the plastic horn button is shattered inside. That is if the airbag system doesn't have that capacitor you mentioned about. Since you know about it so now it's a different case. As I said in my post ask around to ppl who knows as I never had airbags before so dunno how they work. I take no responsibility if the owner of the car decide to open the steering wheel without knowledge.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
