Just wanted to give some positive feedback on my recent service at ERD! They really go beyond your normal service needs every time. I have used them for the last two years including getting my clutch replaced by them and they are top class! Will not take my skyline any where else! I took my R33 there on Monday to get thermostat replaced as it was buggered and also gearbox and diff oil changed. I was going to change the thermostat myself but couldnt get to it cause of my aftermarket plenum but it was no sweat for these guys. Very reasonably priced as well!
Cheers Daniel! See you soon to get my exhaust modified :yes:
https://www.sau.com.au/forums/topic/401386-elite-racing-developments/
  • 3 weeks later...
Just an update. I have managed to take my car for the first decent drive since getting it back from Dan and the guys at ERD. I needed to get a 100,000km service done and while in the process of that getting done the guys found some minor and major issues wrong with the car. The car was only meant to be there for 1 to 2 days but once Dan contacted me with the major issues I got him to do those as well so it took abit longer. The communication from the guys was great and they called me to check if it was ok to do the work when a problem arose. We worked out a plan on to take care of the stuff that needed doing right away and we grouping things together in the future to save on labor costs. Now back to why I am updating this it is because I got to drive my car for the first time since getting all the work done by Dan and guys at ERD and the car has never felt so good to drive. All my major issues are gone and the car has more power now (I had a failing fuel pump) and i couldn't be happier with the quality of the workman ship and the communication from the guys. I'm not really mechanical minded but the guys try to show the problems they fixed and explain everything to make sure you understand why something needs doing and the effects of what can happen if not done.
All in all I have found a workshop where I am confident that when my car goes in it will be left in the best hands it can be so thanks once again to Dan and the guys down at ERD.
I used to be a bit of a loner before I took my car to ERD. A rebel without a cause, with nothing to lose. I also had trouble making friends and talking to women.
Then I took my car to ERD. Now I am married, have twins and have over 200 Facebook friends.
Thank you ERD
Thank you ERD
:yes:
Thank you ERD
You forgot to mention you used to be an 80 lb dystrophic weakling who got sand kicked in your face at the beach until you went to ERD, Now you look like Arnie. :wub:
I used to go to the gym regularly and eat right, but then I just started going to ERD and had better results.
I will be taking my car there again hopefully next week, if I find time, for a bit more work.
Hey when you goto ERD/EFI there is no shit talking you are just enlightened onto a whole other level where the world around you does not understand the awesomeness that you have now become so to them it may appear your talking shit but to the chosen few, the enlightened children the spoken words breathe hope and truth into a world with no light to shine the way.
I used to be asian. After meeting Dan, I turned Fiji-Indian.
I was there it was amazing, he also turned his R34GTT into an R34 VspecII GTR
Its a shame he used all his morphing powers on Choy I was next.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
