Hi guys,
I'm new to this forum actively looking to buy a R35 as a step-up from my current Nissan. I came accross this one in the market, inspected, looks ok.
Does anyone have any info on this car? Obviously it has spent sometime here in Syd. it might have been seen on a track, events etc.
http://www.carsales.com.au/dealer/details/nissan-gt-r-2010-12577832?base=1216&vertical=Car&cr=0&eapi=2&__N=1246%201247%201252%201282%204294963846%204294961487%20898%201216&silo=Stock&Range=Price:Min,Max~0.5&sort=default
Owner claims his wife was driving to the shops all the time, hence low Ks what sounded so "used car salesman"..
Tyres almost gone at 12.5K..not a good sign really.
Anything will help to decide.
Cheers,
K.
https://www.sau.com.au/forums/topic/401390-any-info-on-this-r35/
Its a JDM 2010, so its a 2008 with a complianced plate done in 2010... Since Dec 2008, no JDM R35's can be complianced in Aus unless they are 2008 vintage.
Most of these cars arrived on our shores for less than $90k, and then marked up at a profit in competition with the ADM cars.
And warranty? 3 years aftermarket covering what exactly?? Most Nissan service centres won't touch em with a 40' pole either..
I'm not sure if the JDM multi-function display has english. TBE and Cobb tune.... I wonder if the bellhousing has been replaced, and the miriad of
transmission issues that came with the 2007/2008 models.....
You take your chances IMO, but the price is way too high. Offer $85k take it or leave it.
Edited by Wardski
For that price, I would (actually I did) pick up a 09 and possibly a 10 if you can throw a bit more $ in. Nothing wrong with an import but I don't think it's worth the hassles if it's priced that close to an ADM. It also has mods on it already so I would be vary of the condition of the tranny. If you are dead set on it, take it to a reputable workshop and get a very thorough check. Nissan won't touch it unfortunately from what I've heard as it's an import.
When i was looking at buying one i was told to get an ADM car, I got mine from Sydney just like that one red mine had just over 9000km on it. It cost me $108,000 now it has about 15,000 km,s andd the front tyres are worn out on the inside as well, i dont know if its true but im sure i heared somewhere that the front suspension has 2 settings road and Track, and they are set to track from factory. Before i get the new tyres i will try and get more info on this.
Indeed there are 2 camber settings (street + track). I had mine changed to "street" at the first 2000kms service.
can i get the camber settings changed to road setup at any laser alighnment centre? or does nissan have to do it? if so what are the settings that make the tyres wear out more evenly, This 15000km on a set of front tyres is just not on.
Speaking from personal experience with this particular warranty - absolutely nothing.
Appreciate the feedback. Not touching it, obviously not a best choice.
Good luck mate, i'm sure you'll find a good one. You have fantastic taste in cars.
I'm planning on one of these shortly too, though i'll be going through private sales searching for an ADM one, my preference shall be pearl white.
Cheers.
Edited by iwanta34gtr
Cheers.
Try to get a 2010 or later mate. I almost bought a 2009, but the better MFD screen resolution in the 2010 is well worth it!
Edited by Wardski
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
