For sale
1993 white r32 gtst
137000 km
18X9.5s all round
Tein Coils all round
japanese performance exhaust
new garrett 2871r making 228rwks
nistuned ecu
short shift gear box
hd clutch
greddy intercooler
Greddy boost controller
HKS turbo timer (wired up but not turned on)
dvd touch screen, sub and amp
new coil pack
+ more
Selling because i have a project car and a work ute and both cant afford this car and have no room for it..
great running car and real responsive
$9200 onopost-93034-0-98920400-1338363549_thumb.jpgpost-93034-0-96536300-1338363948_thumb.jpg
contact colin on 0468 318 979
https://www.sau.com.au/forums/topic/401393-white-r32-gtst-228rwks/
