I get asked a lot "What exactly do I need to have my own website". Typed this out in a PM and figured I'd throw it up publicly for a n00b's guide on what you need to buy to have a website.
The question was
hey how do i go about paying this ten bucks a year for my own url? also how much can i store on there?
The basic answer is : -
it varies a lot. You need to pay for a hosting service too.
Not sure how much you know about the internets, but basically, the URL (www.google.com) address tells a persons computer where to go on the internet to find that website. You still need to put the website somewhere, so you have to buy a host to put your files. To use an analogy: - the URL is a street sign and a number, and your host is your house.
Hosting can be from $2-3 a month up to a lot (100+)
I use ***URL.Removed.This.Isnt.An.Add.com.au*** for my hosting, I pay $10 a month and get 20gig of storage and unlimited bandwidth, I chose this ONLY cause it's hosted in AU. ---- U.S. hosting is a LOT cheaper.
The only difference really is that aus hosting is/should be a slight speed increase, and if you want to rank in google then aus hosting helps to make you rank higher for aus searches
If you dont care about ranking and just want cheap, the most reliable would be something like godaddy
hosts like them have starter plans for a URL and a host
for only $60 a year, and you get
  • 10 GB Space
  • Unlimited Bandwidth
  • 100 Email Accounts2
  • 10 MySQL Databases (1 GB ea.)
*100 email accounts is basically bullshit, you can set it up to get infinate emails accounts so ignore that (providing you are the only one going to access them all), and you'd probably only ever use 1 SQL database.
Once you have a host, you will need to point the URL to your web space (if you buy both at the one company at the same time you most likely wont need to do anything). NOTE: It may take a day or 2 for the internet to update and have your new domain actually load your new host.
Then you need to set-up some sort of website. A lot of hosts provide pre-packaged bundles like WordPress for site content and image galleries etc. You can use one of these (very easy to setup) or write your own code... or pay me ;)
Edited by ianjb
https://www.sau.com.au/forums/topic/401402-how-to-setup-your-own-website/
I'd have to recommend Hostgator for webhosting, i spent many hours researching and its unbelievable at how many bad hosts are out there, its a bit more then $2-3/month, i think im paying $11, but come on, thats about the price of a macca's meal, for peace of mind that your website is in good hands! Also beware of cheaper hosts, who hide the fact that you have to pay extra for any useful features.
To answer the question about e-commerce. There are plenty of e-commerce solutions out there at the moment, magento, zen-cart etc, but the problem is you have to build your website up using that cart, you can't exactly just "add" it to your existing website.
If thats okay with you, then you simply have to do a shopping cart search in google and you will have plenty to choose from. If you are like me however and really just wanted something that you could add into your own website, go do a search on Ecwid, it took me hours of searching to stumble upon it, and its the only solution for what i was looking for and its great, and its free.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
