Hey guys,
Up for sale is my 1997 Nissan Skyline R33. This car has been my life for over four years. I brought the car Standard minus a couple of things and spent mega bucks as we all do. Ive only ever put good quality gear on as the list below shows.
The car is a well known as 'Phat as' as it was featured in High Performance Imports Mag issue 140. The R33 is currently Mod Plated for all the modifications (except Screamer), so that puts less stress on people about defects etc.
The car itself has approx 130,000ks and I am happy to take the car to any Mechanic to look over as i know the engine is strong and very reliable. Most of the mechanics/tuning was done at a place called Pro Automotive in Moonah, Tasmania. Andrew (the Head Mechanic) is very well known and id say the best in Hobart when it comes to Imports. The tune on the car currently puts out 300rwkw with the biggest Knock ever recorded at 14. (anything up to 30 is ok).
I am asking $17500 for the car but i do need it gone as im buying a 4x4 to travel to cape york for 6months so offer me something!!
Email me on: fat_r33@hotmail.com
Mobile: 0413926350
Here is a list of the mods below: (Im sure Ive forgotten something)
· Hybrid Front Mount Intercooler – Custom Piping
· Apexi Power FC – tuned by Pro Automotive
· TurboTec Boost Controller (running 20psi)
· Split Fire Coil packs
· Apexi air intake
· Nismo Short Shifter
· Jim Berry Full Monty Clutch (Less than 1000ks old)
· Hi-cas Lock Out Bar
· Walbro Fuel pump
· Turbosmart Dual Port Blow off Valve
· Oil Catch Can
· Front Strut Brace
· Tein Flex Adjustable Coilovers
· Whiteline Heavy Duty adjustable Sway bars front and rear
· After market adjustable Caster Arms
· After market adjustable Camber Arms front and rear
· SSR SP1 -19x9.5+18 (front) with 235/30/19 Kumhos
-19x10.5+30 (rear) with 275/30/19 Kumhos
· Blitz NurSpec 3.5” straight through exhaust system with custom front pipe
· Jet Speed Explosive Body kit
· Custom Shaved boot
· Recaro racing seat on ultra low bride seat rail
· Saber electronic Boost Gauge
· Stealth rear wing
· GTR Cluster with custom carbon fiber overlay
· DVD stereo system
· Pineapple Sub Frame bushes
· DBA Front slotted and Drilled Rotors
· Mintex Xtreme Pads
· Saber ungraded Radiator
· Nismo Thurmostat
· GT3076r with .86 rear housing
· XFORCE high mount manifold
· Turbosmart pro gate 50 with screamer
· 850cc Sard injectors
· Greddy intake manifold
· 80mm Throttle body
· Tinted Windows
Edited by fat_r33
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
