Hey guys,
I really would like to know what are the Garrett equivalent of the HKS GT-SS turbo's?
I have researched for a bit to find many mixed results that they could be either the -7's or -9's
based on the source. However, from my understanding the -7's are actually closer to the
N1 turbo's off the R34 GTR's.
Also, does anyone which is suppose to output more power between the -7 and -9's?
Thank you.
https://www.sau.com.au/forums/topic/401421-garrett-equivalent-of-hks-gt-ss/
GTSS is EXACTLY the same as -9. It's the same part without a pretty badge. This information is in just about every thread started on this topic since SAU started.
For the rest, use the search button. It's been covered so many times, in great detail. There won't be a single question you can think of that hasn't been answered already on those turbos.
There's a 300kw GTR thread, 400kw thread, RB26 dyno results thread, 7's vs 9's thread (not this one) plus more. There's ECU threads, Fuel system threads, exhaust threads, dump pipe threads, intercooler threads, air box threads, clutch threads, radiator threads, brake threads, wheel size and fitment threads. It's all been covered before :)
This may seem rude, but members on here who have taken the time to give very detailed answers and information in the past will find it rude that their past contributions are neglected by other users who are too lazy to take the small amount of time to search when they've given their time to answer the questions already.
Le sigh.....
Will -9's (GT-SS) go well with a 2.8??? :P
No one has asked that yet!
My guess is awesome low to midrange, then a choked top end and drop off after 6500ish due to smaller hotside compared to -5's, and smaller cold side witth more heat if you put in more PSI.
Le sigh.....
+1
....but, They will make more hp than the -7 due to the larger trim on the comp. And a -5 might be too big for him
gtr.uk confussed me so much mate, there quite old posts aswell but people keep saying gtss are -7s ect ect, or they say -7 is bigger then -9 ect ect
The pommie forum has really taken a dive in quality over the lasts few years.
-9's are SS's without actuators and a badge.
The difference between HKS GT-SS and -9's is nothing. GT-SS used to come with HKS stamped front compressors but now they have the same cover as Garrett -9s (and have had it for ages now). GT-SS come with adjustable actuators, -9's don't come with any actuators (Garrett do make bolton adjustable actuators to suit though that can be brought seperately).. although if you wanted standard actuators on -9s then you would want "-1's". For more info: https://www.turbobyg...oductCd=GT2859R
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
