Hey SAUers, I'm not sure how best to describe or if others will understand, but I'll try!
At high speeds, 100kmh ie, even going along straight the car seems.. unstable. Not that it jumps whole lanes, but it feels to me at least like a spider on a hotplate or on ice.
And yesterday after driving in St Kilda for a while on REALLY bumpy roads, it was even happeningish at lower speeds. Once I almost sideswipped a car next to me (I was inside lane, thank god it didn't go over to oncoming traffic), the car just suddenly started going left and I had to turn the wheel right.
Anyway, it is at mechanics, hopefully they find a bush missing or something extremely loose, but does anyone have any ideas?
I realise it is a GTR and has tight suspension and so on, but it seems to me that it isn't just being sensitive to the road.
Cheers!
Don't know about lock bar, but I'll relay that it could be HICAS.
Definitely makes sense that it would be HICAS, as it is definitely some sort of weird steering thing that doesn't affect the steering wheel itself.
Oh another thing, it also seems to happen more not just from going over bumpy things, but by fanging it. IE 1st 2nd to 100kmh, it definitely feels wobbly.
Hicas eliminator is good because it eliminates the outer tie rod ball joints.
More expensive than a lock bar but cheaper than tie rods and ball joints
Those outer rear hicas ball joints are expensive and hard to find.
I think the bearings are ok. Both rears were replaced like 6 mo ago. Bushes should be OK, lots were replaced 6 mo ago as well when I replaced much of the rear.
I'll see what they say then perhaps think about lock/eliminator. I don't really plan on racing or whatever so I'm not sure the pros or cons of having it in for the street, but if it isn't much more then I guess I can go for it.
Meh I'd rather avoid defects to keep life simple.
What does it really do to the driving experience? My mate loves my car and he's got a massive single turbo 1JZ MKIII supra with a crazy diff (only goes to 45kmh in 1st lol) although i suppose his suspension is older and not as good.
Mk3 Supras are a little crude in the rear suspension, but not terrible.
HICAS is intended to produce slip angles at the rear as you turn in, to make the car more responsive to changes in direction. It is also supposed to make continuous small tweaks to the rear steering throughout a corner to keep the car on line. In reality, whilst it may enhance turn in (desirable), what it really does when you are fanging is make the rear do things that you were not expecting. Makes it very uncomfortable to drive fast. And that is while the system is still working properly. Once it starts to f**k up, all bets are off.
They re-aligned it.
It seems better, but still is a massive problem. Twice tonight on the way home along royal parade the car had a mind of its own and decided to 'jump' to the right. Thankfully they are only smallish ones and I react in time, but... damn.
What size / width tires are you running? Wider tires with a lower profile tend to "tramline" or follow the grooves in the road. Wide semi slicks are notorious for doing this, and the car feels like it pulls randomly when it hits a different angle on the road surface. Wide street tires tend to have the same effect.
I'm not sure I will check but they aren't low profile. 265R19 I do believe.
I'm starting to think its gotta be something in the suspension and steering rather than the wheels because sometimes when I break (sometimes heavilyish) the car will pull to the left/right and the steering wheel will actually turn a fair amount as well if I let it.. perhaps?
They re-aligned it.
Can you post how much toe in they dialled in - I had my car aligned too when I just bought it, felt shocking to drive - tramline central, then I went back to the alignment place and checked the toe in, which was left at 0 - now its 1mm or something like that, sensitive but much better.
265's wouldn't help much either - tramlining you all over the place.
I had the same issue with the hicas, after 70km or so it would just kick the ass out but always the same way, i believe the drivers side rear...would slide to the right, very scary, i had the whole system removed and the lock bar installed. I would have rather keep it, but just way too dangerous.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
