Yea its definitely still a problem, sometimes the wheel is perfectly still, yet the car feels like a puck on an air-board and just gliding along with my not having any say. Last night going along at only 70kmh the car definitely wanted to go right, I had to seriously turn left and then back to center to get it right :/
OK, so .... what steering wheel do you have on it? More importantly, is it HICAS compatible?
Have you tried to start a HICAS diagnostic? (google it).
Do you know anyone (mechanic) with a proper scan tool that can report on all the computers in the car? My mechanic has one that reports the computers in the car as being Engine, Trans and Steering (trans because R34 auto ECU has trans module in it - even though I'm using it manual) and my HICAS computer is still present but only partially connected (and completely disabled mechanically). That scan tool reports available fault codes for those computers. Worth a look. You can't always start a HICAS diagnostic to find out if your steering sensor isn't working (for example) because you need the steering sensor (and others) to be working in order to get a diagnostic running!! So scan tools can be a lifesaver.
cheers
Glad I found this topic because my car is becoming increasingly deadly on the road.
Going to be looking at delete or lock as soon as I get some cash.
Would you suggest a delete rather then just the lock bar?
or can a lock bar still bring it stable.
I jacked my car up and you can actually move my wheel because my hicas is so loose..
Don't know on R33s. I put a whole non-HICAS rear subframe from a Cefiro into my R32 and pulled out all the HICAS stuff completely (of which there is a lot more in an R32, being hydraulic).
It's also closer to being legal, as HICAS lock bars are considered a modification to the steering system, which is generally a no-no and an engineering exercise at best.
If I were not to have done the whole subframe, I definitely would have bought one of the more serious delete thingos that replaces the HICAS tie rods with arms with bushes on the end.
Standard GTR wheel from what I can tell. It is possible some sensor is broken or stuck, as for diagnostics I don't think they checked that thoroughly as the loose camber nut was found. But yea I might ask them to do that, I'm sure they have the tools.
These symptoms (or at least the one posted above this post) are usually caused by the steering angle sensor....and more particularly by not having a boss that drives the steering angle sensor.
I thought the same thing but the original steering wheel and boss were in place, I don't believe they had been tampered with, it was intermittent and there was no way to guess when it would happen, either way, all gone, all good.
OP, if you can, just get the system removed and a lock bar installed asap, at least the car will be safe to drive, I know how dangerous it feels, good luck!
Edited by ima_slap_joO
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
