I'd go a deatschwerks fuel pump over a walbro... any day.
Don't use efi hose for e85- you need something teflon lined/rated for alcohol.
For the extra money, I still choose ID injectors over the standard bosch items.
J.
He doesnt need teflon or braided hose the efi hose is fine many ppl are running it without problem. Ive got the stock hoses for last 2 yeArs e85 no problem. Its only worth going teflon if your got a hatch boot and smell is an issue or he has extra coin but it is not a necessity.
J.
I've seen the deatschwerks pumps, but why go that over a walbro?
And I've been told by a few people I need new lines, and then by a few I don't... Hmmmm
Yeah at the moment I'm leaning towards just going id1000's
Definitely go with the Bosch 1000's.
The Deatschwerks is well worth the extra $60. Make sure its hard wired with decent cable as they draw 15-20 amps.
Your lines will be fine for years, if they ever go hard and brittle its time to swap them or upgrade to Teflon.
Im going that walbro 400lph E85 pump. The current walbro 255lph I have has been faultless for the 7 yrs it's been in, even ran it with E85 for nearly a year with no problems. I just need more fuel now to keep it safe.
the 400lph cannot tolerate E85.. there are some components in the pump that will wear with e85.. hence why they brought out the 416lph.. im trying to find somewhere local that may have it. perhaps Aznu?
Well I've only seen it listed as 400+lph, so splitting hairs. The part number you/I want ends in 267 for the E85 approved version. Cheapest I've found so far is eBay US for about $260 delivered but I haven't finished searching yet.
Did you see the result on NS.com. A guy just made 295rwkw on 18.5psi with the tdo6sl2-20g 8cm on E85.
Edited by slippylotion
http://www.full-race.com/store/fuel-systems/fuel-pumps/walbro-416-lph-in-tank-e85-fuel-pump.html
im waiting for a response from these guys, and will probably get it from them if Aznew(authorised walbro dealer) cant get it in
from the 22 nov 2011
Hi Gulrez,
Thank you for your interest in our new 400lph high performance pump. Unfortunately, it is not rated for use in E85. It’s not to say that it won’t work, but we have not validated it in E85 and there are components inside the pump that are not properly protected against the harsh conditions that E85 causes. We haven’t heard of any issues with the pump, but I simply cannot recommend the use of it in your application at this time.
On a side note, we do have an E85 version that we are hoping to launch in the first quarter of next year that should flow beyond 400lph. We’ll have marketing data and flow specifications out to the websites and blogs 3-4 months from now. More to follow soon on this.
Best of luck and let me know if you have any additional questions!
Regards,
Kelly Christians
Account Manager - Aftermarket
thats from Walbro itself. there would have been no reason for them to bring out a 416lph pump for e85 if the 400lph would work just aswell..
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
