Hi,
Well i decided to trade-in my 06 Focus and bought myself a Stagea Series2 M35 ARX-FOUR. I used to own an r32 coupe Skyline 2.5, before i bought my house, since then I had to sell the Skyline for something more userfriendly(karting building materials). This is alot bigger car than my old Focus, so still getting use to the size of it. Got all the luxuries including a twin sunroof and heated wing mirrors. All the gadgets including the useless Tv that cant be use..lol. Been reading alot of posting here on how to get the DVD-rom to change the language. Also im looking at upgrading the front brakes as they are only single pot, any suggetions on Series2?? also in the process of installing a reversing camera this long weekend.
Look forward to interacting with fellow Stagea enthusiasts.
Cheers :no:
https://www.sau.com.au/forums/topic/401461-newbie-from-nz-m35/
Hi Mate and Welcome to another series 2 car!
Please dont say how much you bought it for... you kiwis get it good over there with import prices!
The TV can work, you just need a new digital tuner and install. The Language is a no go unfortunatly. Series 1 to 2 changed the setup, and they dont have the conversion for S2 yet. Have been waiting since I bought it, so don't hold your breath.
Brakes - most anything from R32 through R34, V35/350z 370z will fit with a little / varying degrees of mods. Big problem here is that your stock ARX wheels probably wont fit over the brakes. If you want to stay nissan, go for 18x8+30 rims from a V35 or 350z TRACK wheels, otherwise aftermarket- go nuts.
Lots of info in here- search function is good, however there are a few things changed on the S2 cars so dont be afraid to ask!
Hi, I'm another Kiwi owner of an M35 S2 in the same fairly rare shade of blue. Mine's only a lowly 250RX FOUR n/a model however.
Changing the TV tuner isn't really an option over here as our digital TV standards are different to Aussie, so finding a 12V DVB-T tuner running H264/MPEG4 could be difficult. Some connect an XBox, media player or iPhone/iPod to the aux input of the existing tuner, but whatever you do, you'll need to feed it an NTSC signal as the TV monitor doesn't support PAL. Still waiting for the trip computer language translation also. The Russian translators seem to be struggling with this one.
I believe the late Z33 (350Z) base model used a twin piston sliding caliper on a 320mm x 30mm rotor that will fit; and also go under the AR-X rim.
I have no idea how much they would be, or how hard they are to find.
Yeah bit difficult to get the tv going here due to our digital signal, so im not bothering for the meantime, although i hope to get the reversing camera going so atleast i can utelise the factory pop-up tv screen. Anyone done an install on a Series2??
Things have changed since I last looked.
Here's a 12V Freeview tuner that claims to be compatible with NZ standards and can output an NTSC signal.
See: http://www.trademe.co.nz/motors/car-stereos/other/auction-478825543.htm
The current Japan tuner is fed by 2x integrated aerials (from memory, I think they're etched into the glass side windows), and you maybe able to utilise them as I believe the Aussies guys have with their mods. Sorry, I've never gone down this path with our Stag.
Nice Stag mate. I actually reckon blue ARXs are the best, but then I might be a bit biased.
The M35s do seem to be big cars but your photo with the VE makes it looks small. Did you have the towbar installed or did it come with it? Would love to see some photos.
Given the language conversion is still some time away, an alternative could be to swap out the monitor for the standard pocket and then mount a nav unit that takes a reverse camera input. Or you could do what some Infiniti G35 owners have done and swap the factory monitor for an aftermarket LCD. Here's a link to a thread if you're interested. http://g35driver.com/forums/car-pc/317481-dracovs-carpc-stock-navi-replacement-diy-status-progress.html .
The simpliest option though would be to swap the stereo for an aftermarket 7" double DIN that has nav, DVD and reverse camera input. I believe Chris Rogers has brushed aluminium double DIN facias for sale if you dont have it already.
Just throwing up some ideas for you to think about. I think any one of these options gives much more flexibility than the factory gear can ever provide (even with a language conversion).
Anyway, your Stag looks great and cool number plates as well.
Cheers
Yes I agree, i love the blue colour looks so much better. I got the towbar fitted prior to picking up the Stag from the dealer. I was
originally looking at Skyline 350gt-8 sedan when I spotted the wagon, test drove both, agonised for a week to which one to buy, but I settled with the Stag. Very happy with it, so much space inside. Will be posting some pics for the towbar soon. I might have to look at installing a new tuner at some stage, not important yet just the reversing camera atmo. Anyone use the auto headlight switch much?
I leave my headlights on auto all the time. Only time I manually switch them on is during rain or overcast when it's not quite dark enough for the sensor to trigger, although since I have installed my dashmat they do come on a little bit earlier. The auto feature is great when you enter multi level carparks or similar.
I've got so used to them that when I drive my R31 I nearly forget to switch them off. :-)
Cheers
I've noticed the auto headlight does a two stage switching. Depending on the ambient lighting, it will only turn on the park lights and when it gets a little bit
darker then it turns on the headlights and vice versa. How cool is that!
    • I think you are over thinking it again
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
    • Also, if you're into customizing your ride, you might want to check out tesla accessories model y for inspiration on screen integrations and functionality.
