anyone know how to fill in one of these? i have the alcon 365mm brake kit on front and 33mm alcon rear brake kit?
Brake caliper
FRONT REAR
A mm A mm
B mm B mm
C mm C mm
D mm D mm
K mm K mm
L mm L mm
M mm M mm
A X factor (max. caliper protrusion)
B highest point of caliper (min. radius)
C highest point of caliper (max. radius)
D widest point of caliper (max. radius)
K The upper of between inclination start and end
L The lower of between inclination start and end
M lowest point of caliper
Car center hub
FRONT REAR
E mm E mm
CAR F mm F mm
G mm G mm
MODEL
H mm H mm
TYPE J mm J mm
R mm R mm
YEAR
E Diameter center bore
F Diameter hub
PCD G Height center bore
H Height hub
J Total Height car hub
R Radius center bore (chamfer)
COMPANY NAME
NAME
DATE
TEL NO.
