Rb30/26 Complete Package
RB30/26
Forged rods, pistons,
copper head gasket
o ring head and block (no driving kms!)
moroso single stage external oil pump (new)
siemens 880 injectors (new)
edelbrock fuel reg (new)
single throttle body conversion
remote oil filter set up (new)
steam pipe manifold (used)
Trust 50mm Gate (used)
Garret GT42 Turbo (rated at 1000hp or close too new)
Rb25 Box (used but reco'd)
Os Giken twin plate (new)
Microtech LT12S ECU and X6 Ignition Box with custom wiring harness (used)
Engine was built by TRP, Has never been used it was to go in my VL but then my S15 spun a bearing
so that idea come around but to be honest I am a little unmotivated, Cheap engine for anyone after big power
and the ability to bolt it straight into the existing car, all you will need is a few fuel pumps and a tune 450rwk expected but some bigger injectors in and go for it, TRP is known for there tough motors.
$13500 or best cash offer.
Complete package not willing to seperate owes me close to or over $20k dont like to think about it.
Please msg me on here for a phone number for serious enquiries
  • 3 weeks later...
  • 2 months later...
 Share
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
