Car was tuned today, mods are in sig, The spring used was not enough to go above 15psi so will have to return next thursday to up the boost to 18psi
On the road it pulls hard once it hits the midrange, after being used to 200kw, its taking a bit to get used to lol. Hopefully with 18psi it will see 290-300kw.
whats peoples opinions?
https://www.sau.com.au/forums/topic/401479-opinions-on-my-tune-gtx3076/
  • Replies 94
what is smoothing? it was responding well to boost, started at 210kw at like 10psi, then 250with 14psi so seems a good gain from a few psi,
600NM of torque is pretty good with 15psi ?? its very smooth delivery though, was hoping for a bit more anger in its delivery.
yeah i asked about that, i dont think that dyno is set up for it and was going to be a hassle to adjust, but 120kph is about 3800rpm ,
I bought the wastgate second hand so all i have is a box of springs that arnt labelled, gate was too hot to do a swap. :whistling:
Edited by SliverS2
Went back today for some more boost, amazing what a few psi can do, the car is alot more responsive and fries the rears with ease in second gear, lol
Apparently it wouldnt handle too much timing compared to others so maybe some carbon build up in the motor , i was hoping for an easy 300kw but im very happy with how it drives.
DSC00880
DSC00881
Edited by SliverS2
after opinions on wether it would be good idea to go down to a 0.63housing and add meth injection, the power seems a little bit late and not aggressive enough, did i just select the wrong turbo? or is E85 my answer, i dont really want to sacrifice reliability or rebuild the engine, just after more aggressive power and to hit the 300kw mark.. :whistling:
What rpm are you hitting full boost on? I'm on my phone at the moment so I can't really see the graphs that well...
Wmi/e85 if you can get it could be worth a try, but is that going to give you more response which I assume is what you are after? The .63 rear and e85/wmi will keep you up around the same sort of top end I would think but I'm no expert.
I remember reading about Matt from nistune' r34 gtt making around 290rwkw or possibly more running a gtx3071 in .63 on pulp with poncams.
The thread is over on the nistune forums, but from what i remember reading his car has always made more power than expected from the mods he did.
Edited by Mitcho_7
I experienced Mafia's 0.63 + WMI setup. Stronger than mine with 0.87 on pump 98 from 3-4000, but also you could feel the torque rolling off above 6200-ish where mine with the larger housing kept pulling to 7200.
Honestly IMO this result with a 0.8 housing on GT30xx at 19psi is entirely respectable and typical of what power figure to expect. +10kW would be nice but it's within range. The whole GT/GTX thing isn't worth wasting time on. Flow maps shows that the GTX only has a flow advantage at higher PR (boost).
For a more "aggressive" delivery simply lift the head and turbo setup, and install on a RB30 bottom end. Much more impressive day-to-day.
Alternatively, check the existing setup over for integrity, and wind boost up to 22-24psi with the controller setup for the most aggressive rate of boost build that you can. If it fries tyres now, then your local fitters will be seeing you on a monthly basis after that.
Can I suggest forget chasing more power, more power, and target more traction/drive with what you have?
Is yours internal or external gate? Perhaps the wastegate isn't set up correctly or doesn't have enough spring to hold back the manifold pressure? That would make it come on very slow and progressively build boost like on your graph.
If it is, do you have a mac valve? You need to feed boost pressure onto the top port on the wastegate until your controller switches it to the lower port. Which spring did you get and what is the lowest boost pressure you can run?
Have you tried more boost?
KiwiRS4T-The tuner said that he has reached the limits on the 98fuel, he added just one degree more timing and it went from 278 to 285 but he said the knock was climbing too much so for safety he took it back a degree to 278, also said there might be some carbon build up inside because some rb25's can put more timing into them.
Mitcho_7- full boost looks like 4400rpm 18psi, but when its set to 15psi it takes till like 5000rpm to get there,
DaleFZ1- I wouldnt mind rebuilding a strong Rb30 bottem end if it were straight forward swap but reading the rb30/25 looks like it gets expensive very quick.
Scotty- Its external gate, 44mm tial comming off exhaust housing, The tuner set it up, it has one hose going in top and one hose at the bottem, looks like theres heaps of duty to bring it on early, will double check though
The tuner tried all the springs like 5 of them, the low boost setting is .8bar so whatever that spring is .
What would be best/cheapist option for earlier and more aggressive response/power? RB30bottem end? water meth?E85? Housing swap? low mount aftermarket exhaust manifold?
Edited by SliverS2
KiwiRS4T-The tuner said there might be some carbon build up inside because some rb25's can put more timing into them.
WMI can help with cleaning that off from what i have seen and as an added bonus you get more power!
If you go WMI, keep a copy of your current tune so you can revert back to it later on if you decide to ditch the WMI. That way you dont have to pay for another tune.
Edited by Mitcho_7
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
