if you compare micko's gtx3071 with the gtx3076 the power curves are almost identical, even the boost response is identical, i do admit i have cams ( not sure if they really benefit the boost response, might even slow it down) and external gate so maybe this has brought my turbo up to his level , but the difference in boost levels is just as significant, im running 5-6psi less in the whole rev range..
Seems the gtx3076 has been taking a bad wrap for a long time, and the gtx3071 is described as more responsive/better turbo and the turbo of choice, compare the two graphs and they are equal, the gtx3076 should even be in first place, and with over 350kw potential its a winner in my eye..... obviously setup dependent ( external gate, E85, proper tune, engine condition etc)
might add some in car footage soon ..
Edited by SliverS2
  • Replies 94
That's the issue Mark, not many cars have a good enough setup to attain those sort of figures, and that's why it got a bad name. Stock manifolds or 3 inch exhausts aren't going to cut it, we are talking 4 inch system here, and how many would run that on the road.
I can say after running both the GTX3076 isn't quite as responsive as the 71 but spools in a similar fashion, with approx. 40kw higher potential imo.
I think the gtx range is very impressive going off some of the most recent results.
But I personally would probably still sway to the gt3076 If I didn't want to run more then 18-20psi and was internally stock. The gtx3076 would be epic on a built 25/30 running an external gate and pumping 25+psi.
Has there been any twin scroll setups for the gtx3076 to combat the smidge of extra lag?
Edited by Mitcho_7
Yep, its in the RB25 results! Was REALLY responsive...... Wish i went that way now!
The only one I can find is a regular gt3076r twin scroll that Scotty did the exhaust etc for. It's got a pretty freakin epic looking graph on 98 let alone the e85 tune!
What is the difference between the gtx3076 and the gt3040 wolverine?
I have a GT3040 sitting in the garage, I reckon it will produce the same numbers on E85 as a GTX3076 but much cheaper.
How much you after? That is the 3082 equivelent yeah?
I think the compressor is bigger? Power potential is similar though!
Yep, GT3040 is a GT3082.
The compressor is an 82mm compressor with similar flow potential of a billet 76mm compressor. Same 60mm turbine.
My GT3040 has extrude honed front and rear covers. I changed to a TS GT3076 so the old turbo is still sitting in the shed.
i dont know much about gt3082's, my turbo doesnt feel like its an on/off turbo like the gt3082sounds, mine feels very efficient and on throttle is torquey even off boost and with 5psi in third is taking off, the mightly rush happens at 4000-4500rpm and never runs out to 7000rpm, but its not like a switch, up some steep hills it will pull you in the seat even at 3000rpm...
so without experiencing a gt3082 i cant say, but i can say this turbo is showing its presence even without the 4000rpm etc revs...
i agree though if you dont want to run atleast 20psi then the gt is better...
Ts housing on the 3040 for science?
Or will it not fit?
TS housing would fit .
If I had a highmount manifold, for science, it would go on. Since there was enormous difficulty getting the manifold, oil drain etc fitted with an RB25 from a Stagea in the R33 there is no chance the current turbo is coming off unless the engine comes out.
Sounds just like a GT3040 which isn't very different from a GT3076 in my experience.
  • 2 months later...
Just read the whole thread, sounds like an impressive build.
I've got a fresh forged + camed 25 waiting to go in my 32, Gtx3076 + ext gate + 20-22psi on e85 seems a good way to go in your experience?
I'm still tossing between 76 & 71..
Out of interest, a local workshop here have done a built SR20VE+T using a GTX3076R and tuned it to 30psi and made a fairly impressive 477kw @ hubs with it. When given a bit of shite about dyno setting fiddling they gave a bunch of info on how they ran it so people can scrutineer it for themselves.
Looksy here: http://www.shredmotorsport.co.nz/2012/sr20vet-results-and-the-truth-about-dyno-corrections/
i dont see the point in a gtx3071, the gtx3076 seems to respond just as good and makes more power from the dyno graphs ive compared and with less boost,( micko's compared to mine for example) im still thinking wether the 0.63 rear would of been the best option seeing my power goal was 300-320kw, the spooling and area under the curve may have been better and still had the top end, thats using E85..
Edited by SliverS2
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
