Hey guys,
I'm no longer going through with my RB25/30 build as I'm looking to buy a new car so the parts I have been collecting are now up for sale. Heaps of these parts are brand new and haven't even been test fitted. Save yourself some money and buy the parts off me!
Item: RB25DET Head
Condition: Used
Comments: RB25 Head from an R33 with supposedly 150,000kms. Complete with cams and gears, valves etc
Selling for: $420
Item: LS2 Coilpacks
Condition: Brand New Never Used
Comments: Set of 8 Brand new OEM GM LS2 Coilpacks. These are super strong coilpacks that handle very high HP with no problems. Many guides online for converting them on an RB25 (can probably easily convert SR20 too). Much cheaper than other alternatives, plus a set of 8 gives you spares. Delphi part number D514a
Selling for: $180
Item: LS2 Coil Plugs
Comments: Set of 6 Coil Plugs to suit LS2 Coils. Use these to convert your wiring harness to suit LS2 coils
Selling for: $50
Item: Bosh 040 Fuel Pump
Comments:. Brand New Genuine Bosch 040 in tank fuel pump. 400hp capable. Ordered directly through Bosch from Supercheap Auto
Selling for: $200
Item: 500cc High flowed Injectors, stock fuel rail and loom
Condition: Used
Comment: High flowed R33 Side Feed injectors in a stock rail. Comes with stock fuel rail, hoses and injector loom
Selling for: $250
Item: RB25DET Greddy Copy Polished Plenum
Comments: Comes with all fittings and hoses. Polishing isn't the greatest in some hard to reach spots but all round pretty good. Great internal quality, smooth runners with no internal slags
Selling for: $220
Item: Q45 Throttle Body
Condition: Used
Comments: Good condition Q45 Throttle body complete with throttle position sensor. This will bolt on to a plenum such as a Greddy / Freddy or ca be adapted to suit stock manifold. Fair upgrade in size over the stock one.
Selling for: $100
Item: 3" Split Dump Pipe for R32 / R33
Condition: Used
Comments: 3" Split dump/front pipe. Great condition tos uit R32 ad R33. Maybe R34 but not too sure
Selling for: $150
Item: T3 Wastegate Adapter
Comments: Spaces turbo away from manifold and adds a flange for a 38mm wastegate. Great for a big turbo setup or adding external gate to a stock manifold
Selling for: $60
Item: RB30 Head Bolts
Comments: Head bolts for an RB30. Comes with a pack of grease
Selling for: $40
Item: RB30 Cometic Metal Head Gasket
Condition: Brad New Never Used
Comments: Brand new MLS head gasket. Stock size and 86mm bore
Selling for: $230
All items located in Wagga Wagga NSW. Pickup is welcome, can deliver at your cost. PM me or text on 0437480958
pm me price of coils and plug posted to syd plz
PM Sent
The HEAD bolts are they RB25/30 or just RB30 bolts
As far as I know they only suit RB30. If you were doing an RB30DET conversion, I'm fairly sure that you need to get RB25 bolts
PM Sent
yes I know I was just making sure
These are normal ls2 couls not the truck version yer? Pm price posted to S.A
Yep normal LS2 coils. PM Sent
  • 1 month later...
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
