Yeah ive seen him around a few times as well..... Does look nice.
Completely unrelated but whos car is this? Nightmare? Is he a Sydney member of SAU or something? Its one of the nicest R33s i ever saw.... Love that Kakimoto kit.
http://members.optushome.com.au/sabretooth...ee/DSCN2823.JPG
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-65260
Nice pic! Haven't seen the Skyline with "PANIC" plates but one of the nicest Skylines I have seen is the one my mate recently bought. Its also a SII silver Skyline and he took it on the recent SDU cruise a few days after he bought it. It has a Nismo front lip, a boot lip and 5ZR 5 spoke rims. It's simple n neat but aggressive at the same time.
It recently put out 235rwkW at a dyno. You should see the interior too! Light grey leather trim.
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-65797
Originally posted by WASSABI
still reckon "GT N1K" is the sickest gtst in perth... drove past speedworks tonight, it was there AGAIN....
YES!!
Has that car got THE sickest rims or what?
If he's at PAS this year, i'll be bringin a mop hey... (for the drool..)
and loooove that BIG33, only it's a little too whale-like for me :D
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-66330
Adam32,
He has a bigger turbo, HKS pod filter, 550cc injectors, fuel pump, intercooler, full exhaust, Apexi PFC, Apexi AVR, forged pistons, gasket. Has a few other bits and pieces done to it.
On ordinary days he runs it at 0.8bar but he boosts it to 1.3bar when he wants to drive hard.
The best part of it is that he bought it as is and it had only 27,000km on the clock as the guy he bought it from has another 3 cars.
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-66376
Was he trying to pass it off at the last auto salon in February this year as an N1? then we saw the 2.5 litre under the bonnet?
It was a VERY nice looking car which big spoilers and sick mags but yeah i some people were undere the impression it was an N1 frfom his numberplate or badging or sumfin...still sounds pretty sweet now with those mods on it!!!
Oh talking about N1 the ex Joe Crisafio GTR n1 that was 4 sale was sold about a month ago.... he got PSI to service it a few weeks ago... it was very nice...Brett drove it into the workshop and even that was enough to make me drool.... i had a quick talk to the owner he seemed quite happy with it as you would... bit dissapointed though about non airconditioning but thats what you get with a true race bred car.... it is a nice white one with LOVELY Nismo mags! SEX ON WHEELS!!
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-66561
Was the N1 GTR from Crisafio? I think that used to belong to Paul Rogers (ex-Perth Wildcat, now Adelaide 36er), who has upgraded to an R34 V-Spec.
GT-N1K is owned by Nich, thus the N1K part of the plates. It is always at Speedworks because Basil, formerly of Baz Motorworks and now head mechanic at Speedworks, built the car.
It is a animal, lots have gone into it.
:uh-huh:
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-66580
Not sure if he is putting it into Western Salon, I imagine he would, afterall it is a showcar...but one that seems to be driven a lot!
Mods that I know of,
cosworth pistons, conrods and balanced crank.
port and polished cylinder head (got a lot more flow out of this)
turbonetics t66
haltech
trust external oil cooler kit
850cc injectors
custom intake manifold
bosh fuel pump and surge tank
OS giken twin plate
lots more....
https://www.sau.com.au/forums/topic/4015-panic-r33/#findComment-66612
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
