ok so my bosdh intank fuel filter keeps clogging up andgetting f**ked by debris in my tank.
it seems filtering my tank by using pumps in kinda expencive.
so i was gonna buy a new tank but i suppose i can get mine cleaned propperly.
i dont know if its random dirt and crap or if their has been standing watewr in their at some point and their is developed rust or something.
my question is where in adel should i go to have it cleaned and what is involved in cleaning a tank properly? can it be done myself?
https://www.sau.com.au/forums/topic/401560-fuel-tank-clean-in-sa/
interesting
fits but you need preety much everything associated with it.
so:
tank
straps
sender/pump
gauge (as that is cal'd to the 72 lt instead of 60.)
tank and straps i would get together
pump i assume a bosch internal pump will do like the gtst (needs to be replaced again anyway)
sender- would this be for the guage?
and guage....why would you replace this would the new sender just give the propper reading for the extra 12ltrs?
Cleaning the tank your self is pretty easy mate. Unfortunate accident caused a fuel fire while i was changing my fuel pump wiring. Any hoo i needed to clean the tank out after from melted bits and bobs. Its only half dozen bolts or so and a few hose clamps. Shouldn't take longer than 15 mins to drop it out. Drain it and go buy 10 cans off carbie cleaner and go wild. Inside of your tank should be clean i would imagine your only wanting to flush out shit that's gotten into tank.
Its pretty simple just make sure that once your done you give it a good 2/3 days dry time after you've cleaned it.
If you've got rust issues i wouldn't risk using even if you clean it.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
