itshimdazza Posted June 1, 2012 Share Posted June 1, 2012 any in the SE suburbs available to borrow a TPS for 5mins to check out my car? Have a problem with the car not revving past 2000rpm & have changed the AFM (Z32) and now suspecting its the TPS.. Regards, Darren Cranbourne Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/ Share on other sites More sharing options...
paulr33 Posted June 1, 2012 Share Posted June 1, 2012 if the TPS was toast id expect your idle would be pretty ordinary or it would idle peg at like 1100rpm constant how does it idle the engine check light would also be on for f**ked tps there is no rev cut that im aware of for dead TPS, but there is for dead AFM, it caps at 2500rpm Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381215 Share on other sites More sharing options...
paulr33 Posted June 1, 2012 Share Posted June 1, 2012 from the service manual, note the item in red and green when TPS is dead the car just runs as normal when afm is dead, rev cap at 2000rpm Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381220 Share on other sites More sharing options...
scotty nm35 Posted June 2, 2012 Share Posted June 2, 2012 I had a look at it last night for him, its a z32, I tried the solder fix, no good. I swapped it for another z32, still no good. Perhaps they were both dead? I cleaned the plugs etc but the ecutalk was showing a good afm voltage output so we looked elsewhere for the source of the limp mode. Do you know anyone with another z32 to try anyway Darren? Otherwise you may need to get the wiring checked. We noticed the tps on the ecu talk wont drop below 2.3v, shouldn't it be set to .47 or so at idle? The idle isn't very good either... One other thing, the 2k rev cut only seems to happen when its at operating temp. Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381304 Share on other sites More sharing options...
itshimdazza Posted June 2, 2012 Author Share Posted June 2, 2012 Unfortunately I dont know of anyone with a spare Z32 AFM to swap & check. But if anyone reads this and is willing to let me test this out for 10mins I would be very gratefull.. I live in Cranbourne. The idle has always been a little high & I need to cleen my AAC as sometimes it gets upwards of 1800 or so (another problem) Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381330 Share on other sites More sharing options...
W0rp3D Posted June 2, 2012 Share Posted June 2, 2012 i have a tps here im not using, i also have a Z32 but its on my car and a bit of a prick to get off so if you wanna borow the tps first to check that would be best, i'm in frankston. Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381364 Share on other sites More sharing options...
itshimdazza Posted June 2, 2012 Author Share Posted June 2, 2012 (edited) Damm Brett, would of been over there if only I had seen your post. Thanks anyway for the offer though mate as I just just picked up both AFM & TPS. Now when i went for a drive and fanged it to warm it up to operating temp 80degrees or so and its now not doing the 2000rpm cut WTF? I at least have these spares now so that when it starts i can change one at a time to see if it fixes the fault Does anyone know exactly the operating voltage for the z32 AFM & TPS for Ign, Idle & WOT (R33 GTST SERIES II) Thanks, Darren Edited June 2, 2012 by itshimdazza Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381467 Share on other sites More sharing options...
scotty nm35 Posted June 2, 2012 Share Posted June 2, 2012 How was it on the way home last night? Perhaps there is a loose wire in the loom, or corrosion in the plug that we managed to dislodge? Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6381611 Share on other sites More sharing options...
itshimdazza Posted June 4, 2012 Author Share Posted June 4, 2012 no prob's either Scott on the way home. it may be the plug . not sure if you can pull the wire out of them or not to resolder Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6384437 Share on other sites More sharing options...
paulr33 Posted June 10, 2012 Share Posted June 10, 2012 get the service manual and look it up .... ? TPS at idle (or closed throttle) should be 0.35 ish v to around 0.40ish volts. if you are seeing 2.3v at idle or (closed throttle) your sensor is f**ked or throttle body isnt closed properly AFM at idle for standrd AFM or z32 should be around 1.1v ish give or take. be sure to note, with IGN on, but not engine running, AFM (regarless) should be 0.5v ish TPS should be 0.33v ish. with engine running at idle, AFM should climb to 1.1v instantly and TPS should be the same unitl you press the accel pedal Link to comment https://www.sau.com.au/forums/topic/401566-borrow-a-tps/#findComment-6392273 Share on other sites More sharing options...
