Hey guys!
im in a bit of a predicament here! in the middle of replacing discs need to finish so i can get to work tom!
How do i remove the rear discs? i have pulled the wheel and caliper off, but the thing wont budge! do i have to undo the huge 36mm nut for the hub to remove?
thing is the DBA 4000 rotor looks like it would slide over that hub?
i removed the rubber plug and unscrewed two spring tentioned screws, but still wond budge.
and yes handbrake is off.
HELP PLEASE!
thanks!
https://www.sau.com.au/forums/topic/40158-urgent-removing-rear-disc-on-r32-gts/
Sorry I don't think I will be able to help.
But do the R32's use the caliper for the handbrake or a drum type setup.
Just making sure that you have the handbrake off...
I know what it is like to be in a big hurry and things not going well.
Sorry if this is just plain stupid :Oops:
There are 2 threads in the disc that take a 6or8mm bolt.
Screw a bolt in each to put some tension on the disc , spray some CRC around the hub where the disc slides over and tap the h/brake drum part of the disc lightly with a hammer.
Cheers
Ken
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
