Hi all.
I'm stripping my car out so wanting to move all the interior trims and stuff I pulled out.
All in good condition.
Driver and passenger seatbelts - $35
Rear wiper with motor - $5
Hood lining with interior lights and sun visors - $50 Can separate.
Centre console with decent hand brake cover - $40
Glove box - $25
Door trims both sides - $60 for both
Rear seat side trims - $20 for both
Heater, A/C, fan unit. (under dash). Has had the A/C lines chopped but heater core and fan are good. - $50 can sell just the bits you want.
A pillar trims - $10
Climate control module - $40
All prices negotiable
Located Ringwood Vic. can post for extra.
Please PM
Russ
  • Replies 66
Posted Images
Update...
Hood lining with interior lights and sun visors - $50 Can separate. Sun visors sold. $30 for the lining and lights.
Glove box - $25
Door trims both sides - SOLD
Climate control module - SOLD
hey mate interested in the speaker grills on the front door trims dont spose youl separate?
Door trims are available again. Original buyer doesn't require now
Are the rear seat side window trims still available. Cheers
Now available. Original buyer doesn't require now
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
