  • Replies 66
Posted Images
  • 3 weeks later...
Update...
Driver and passenger seatbelts - $35 Drivers side SOLD, Passenger $15
Rear wiper with motor - $5 SOLD
Hood lining with interior lights and sun visors - $50 Can separate. Sun visors sold. $30 for the lining and lights.
Centre console with decent hand brake cover - $40
Glove box - $25
Door trims both sides - Available again. $40ea or $60 for both
Rear seat side trims - $20 for both SOLD
Heater, A/C, fan unit. (under dash). Has had the A/C lines chopped but heater core and fan are good. - $50 can sell just the bits you want.
A pillar trims - $10
Climate control module - SOLD
Adding the rear quarter window trims. $40 for both.
also still got driver side kick panel. $15
Hey mate do you have the ash tray from the dash?
Yes I do however I cut the back out of it for the turbo timer when I used to have one, Looks 100% from the front. $10 and it's yours.
They'll fit the same. Dunno if you have the shiny finish or the elephant scrotum finish lol Pretty sure mine is the shiny finish.
If you're not in melbourne and not willing to pick up I won't be able to post until after WTAC in 3 weeks when I have time to pack things up and post.
thanks guys.
Hey bud - got passenger side dash vent?
No sorry but my mate might have one. http://www.skylinesaustralia.com/forums/user/79141-rossib/
Got a good condition parcel shelf brake light?
No sorry. They're only for gay aussie compliance?
centre vent was smashed when the roll cage builder went to pull it out. Ash tray I think is spoken for but hasn't been picked up yet. I'll give him a few days. I'll get back to you if he doesn't grab it.
Ash tray sold. Sorry Kris. My other mate is going to be wrecking his 32 GTS4 so he might have one. PM him. rossib is his user name
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
