Update...
Driver and passenger seatbelts - $35 Drivers side SOLD, Passenger $15
Rear wiper with motor - $5 SOLD
Hood lining with interior lights and sun visors - $50 Can separate. Sun visors sold. $30 for the lining and lights.
Centre console with decent hand brake cover - $40
Glove box - $25
Door trims both sides - Available again. $40ea or $60 for both
Rear seat side trims - $20 for both SOLD
Heater, A/C, fan unit. (under dash). Has had the A/C lines chopped but heater core and fan are good. - $50 can sell just the bits you want.
A pillar trims - $10
Climate control module - SOLD
Adding the rear quarter window trims. $40 for both.
also still got driver side kick panel. $15
How Upto date is this list and are u able to bring stuff to Sydney for WTAC?
Edited by krayzie32
  • Replies 66
Posted Images
That is up to date. Happy to bring things up to WTAC at Eastern Creek. Let me know before wednesday 8th as I'll be coming up that day.
  • 3 weeks later...
Hey mate, would ya have the rear 1/4 window trims?
Yeah mate. Pretty sure I've still got them. Reasonable condition but they're not 100% so $40 for both.
  • 3 weeks later...
  • 1 month later...
Still parts available. Give me some offers, not really chasing money, just trying to clear these parts to someone that needs them.
Hey man, you got any dash vents? My bogan mate put his feet up on the dash and busted my vent. You got any vents?
Cheers.
P.S please let me know if you have any dash vents. Thanks.
Hey was wondering if when the a/c was in the car was it working. If so can i grab the tx valve out of it.
Cheers.
You'll have to elaborate on what that is. A/C has been out of the car for like 5 years but might still have it. It did work.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
