Hello everyone, I am currently looking for a new or used 370GT Steering wheel airbag module and engine cover, I have a 2011 Infiniti G37 Sedan in the US, which is a 370GT sedan. I am willing to trade for my US versions ones if some one is interested. Must be in black and good working condition, I am a member over MYG37.com but seems like no one is ever selling those items in the US, so i figure i give it try here, Thanks! Let me know guys! Appreciated.
I traded my V35 airbag cover (not the whole unit) with a guy from G35 driver after searching for a while to find a person that was wiling to do so. I also picked up an engine cover which again took a while to find someone that was willing to ship it. Surely someone can help you with this.
Possibly you are the same guy who started the same thread on myg37.com. I will post the same thing here that I did there. If you can't find someone to trade then give this guy a call/email in Japan "rhdjapan.com"
He might be able to source a second hand one for you. If the new ones are $2000, second hand ones may still be expensive though.
I would hang in there & you will find someone like I did. It took a while but once I found the right person it was all done & dusted very quickly & at a small cost.
Dunno if these are what you are after - the whole steering wheel from a V36 - but they are available on Yahoo Auctions.
http://page5.auction...tion/e119414669
http://page5.auction...tion/e118440805
The Import Monster links are below if you want to have them deliver them to you or you could always buy via bidjdm.com
http://www.importmon...title=V36%20GPB
http://www.importmon...7.jpg&title=V36
I have the airbag, engine cover, wheel centre caps and front grille (coupe) if anyone is interested.
Also Nissan and Skyline Trunk emblems (will need re-tapeing)
PM you about the parts. Interested in the engine cover and airbag module. Thanks!
  • 3 weeks later...
  • 8 months later...
  • 2 months later...
  • 1 year later...
Sorry for digging this one up, but I was wondering the same thing about trading (or buying) the airbag cover and possibly engine cover from infiniti to nissan. Been looking for these for quite sometime in the US with no luck at all.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
