Having a few issues with the the car when on the road in any gear if it hits .5 bar the engine cuts very smooth cut, no struggling no missing just bam that it nothing. untill your fully off the accelerator then it comes back to life, you can have the throttle 3/4 open and will rev to limiter.
history of things i have tried,
removed all turbo side replaced all gaskets lines that looked bad and clamps.
replaced TPS and AFM
removed factory boost solinoid and run manifold pressure to wastgate
removed all cooler piping and replaced some clamps all ok
changed plugs gap .8
running out of ideas?
https://www.sau.com.au/forums/topic/401653-r33-gtst-boost-issues-05-bar-cut/
stock ecu on it, have an apexi boost gauge i have just connected for testing. makes boost ok but at about 6k its creeps up slowly from .45 bar and when it hits the .5 it cuts.
That was my first thoughts it was hitting the boost cut but my understanding thats at 1.2bar?
There is no "boost cut" on Nissan ECUs (alright, on the Neo, which actually has a MAP sensor connected to the ECU, there is a boost cut). But certainly not a boost cut on R33 ECUs.
What you DO have is a load based cut. When the ECU calculates a TP value (based pretty much just on AFM reading) which is too high, you get a cut. This can actually happen at a whole different range of boost levels, depending on how much other modification the car has (exhaust, bigger cooler, etc) and the weather, etc.
What I would suspect is that the boost gauge you are using might not be accurate, and somehow you have more boost than you think you do. Consider this one unlikely. Or you have a big boost leak that you haven't found, leading to high air flow at the correct boost in plenum. Or you have a faulty AFM.
Ok changed a few bits has made it abit better.
Timing was set on 0deg so set cas to 15deg.
Factory boost gauge sensor was missing so grabbed one of another wreak out back now factory cluster works only goes halfway up won't go to the 7, which should be correct for 7psi.
Have connected factory boost solinoid.
Seems to get to 6500rpm now then cut.
Can't be afm as I have changed that.
But have noticed there is a beep from the ecu when it hits the cut?
limiter is at 7200
And I know the factory gauge 7 on it is about 14psi that what I said it only goes to half which would mean its running 7pis = .5 bar or there abouts.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
