im after another silvia im after a r32 skyline or s13
this has been my daily for a year and a bit and it has never failed me!!
im the 2nd owner of this skyline
its 87 model series 3
has brand new Ksport coilover 36 way damper adjustment, camber and height. really nice ride
s13 front end, hubs, turbo sr20 brakes,knuckles also has brand new tie rod ends
auto
SSR Vienna Kries (rare) MASSIVE DISH!
18x9 +24 with 20mm bolt on spacer federal 595 215 40 18
18x10+24 8mm spacer 225 40 18
extractors with std exhaust to keep it quiet
will come with 12 months rego!!
new radiator
has few small dings in rear left quater cause i had a diff in the back and it rolled around
after a swap and cash adjustment depending on how clean the car is
see pics below
0450 283 887 located on the northern beaches sydney
Edited by 20's_plenty
https://www.sau.com.au/forums/topic/401660-baller-daily-driver/
    • yeah, there's a country that recently started importing Skylines, I blame them.
