Selling my dads 1995 Zenki S14. Has been driven by a 60 year old for the past 2-3 years. Was ment to be a project car but couldn't be bothered with it.
Nothing wrong with the car mechanically, outside paint isnt the best.
Old man gets 100kms per 8.5lts.
Perfect daily has never been pulled over before or been thrashed.
-SR20DET
-5 Speed
-White
-Stock suspension
-3in Turbo back
-Front mount
-Turbosmart dual stage boost controller
-Pod filter
-Some Pioneer Headunit, has speakers and tweeters
-Has 18" rims of some sort.
-Has 294,000kms on the clock but previous owner has changed the engine.
-No RWC
-Rego till November
$6,000 Car is located in Sunshine West, no timer wasters. car can be inspected on weekends or on weekdays after 6.
PM/Call/SMS 04511 5111
