1. Work Equip Copies (Sterns Racing) wheels for sale:
18x8, 18x9.
Unknown offset- pictures show how they fit on my R32 with no spacers- I have also included a picture of actual work equip's on a 180sx...
Looking for $400 ono - No tires, $700 with tires- Road worth condition fronts, rears 80% tread.
Very Good condition- small gutter rash on one wheel, not noticeable at all.
2. Bride Brix 1.5
Perfect Condition, no rips. no tares. no bolster ware.
$450 No Rail.
3. Twin Cannon Exhaust- Cat back
Very Good Condition Twin Cannon Catback Exhaust. 3" then splits into two 2.5" before cannons. Includes Mid muffler.
Two piece system- Relatively Quiet. (Bit louder than my Kakimoto Regu 92z)
*This was on my 4door. I bought a Trust DD Exhaust which was meant for a 2 door and it fit my 4 door- so i assume 2door and 4 door exhaust length is the same*
$250 ONO
4. R32 2 door Full Vertex Kit
$350 for the full kit- Fitment is very good. Will need paint- (Faded black in colour) - Came off my car when imported from Japan.
5. R32 4 door BN Sports Aero
Rear Bar, Side Skirts- Front bar is a different colour to the rest of the kit.. Rear and sides are in VGC, freshly painted spark silver KLO.
$400 ONO
6. Factory RB20DET Turbo
VGC Minimal shaft play, came of motor that had done 88,000kms.
$150 ONO
7. BNR32 Radiator
$50- been sitting in my garage for 2 years. No leaks. Probably could use a flush. (I installed an aluminium radiator- dont need this anymore)
Located in melbourne-
also interested in the wheels, would love to know approx. offset and see some more pics. You can pm me or txt me on 0406344814,
Thanks
  • 1 month later...
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
