Hey guys,
Quick question. I am building the DR for circuit racing (on a budget) so I'll be running the car with a standard engine for the moment. The car will not be registered.
There is a hell of a lot of pollution gear under the bonnet and back in the day on a carboy car you could just disconnect it all and plug up all the air leaks and she'd run fine. What I want to know is if I do this with the FJ will it still run okay? If not are there any tricks (other than going to an aftermarket computer)?
Help definitely appreciated.
Cheers
https://www.sau.com.au/forums/topic/401670-dr30-fj20et-pollution-gear/
Ur on the right track bin it all. If its bone stock itl have a boost valve on the r/h side of the inlet blok it off or put a blow of valve there. And adjacent to that there be a similar valve with vacum lines going to it. Piss that off asweel make a plate to block it. Basicaly strip all the gear off the inlet mani so u pretty much only have injectors there
Ɨ
Ɨ
