How are you "Finding Nismo" products in general?
Some are useful - others cosmetic
Some are oldies but goodies - some are discontinued
Some are well designed - some are designed better
Would you like to...
1) Post a Pic of a favourite that you own?
2) Post a Pic of a let-down?
3) Caption the Pic with a comment?
My S-Tune Susp'n has served me really well so far...
https://www.sau.com.au/forums/topic/401681-finding-nismo/
Springs in my Stagea are great. The rates are very nice and compliant for daily duties. I think the suspension dept is sorted. Catback Exhaust my avatar is good, very quiet,but retains a nice note with nil drone. Great for daily too, however I believe it's a bit of a restriction in the rear can. Quality also great.
https://www.sau.com.au/forums/topic/401681-finding-nismo/#findComment-6382527
I do.
Just the icing on the cake.
But they look like the short version.
I've got the extended ones.
Yes, mine are the short ones at 5 o'clock in the pic.
But I like your wheels > I bought 'em.
Sigh - discontinued!!! Prices/values seem to have gone sideways now!
  • Like 1
https://www.sau.com.au/forums/topic/401681-finding-nismo/#findComment-6382547
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
