Id say that I would compete for the title of "biggest Nismo whore" in this thread, Simon can probably confirm haha
My recently acquired Vspec R34 has the following;
ENGINE
35]
NISMO OIL - AIR SEPARATOR
35]
NISMO REINFORCED TIMING BELT
35]
NISMO INTAKE PIPING
35]
NISMO INTERCOOLER
35]
NISMO INTERCOOLER PIPING
35]
NISMO ENGINE OIL COOLER
35]
NISMO ADJUSTABLE FUEL PRESSURE REGULATOR
35]
NISMO HI-FLOW FUEL PUMP
35]
NISMO IRIDIUM SPARK PLUGS
35]
NISMO RACING RADIATOR CAP
35]
NISMO R-TUNE AIR CLEANER DUCT
35]
NISMO OIL FILLER CAP
DRIVELINE / CHASSIS
  • NISMO G-ATTACK COIL OVER SUSPENSION
  • NISMO SUPERCOPPERMIX COMPETITION TWIN PLATE CLUTCH
  • NISMO FRONT AND REAR SWAYBARS
  • NISMO LONG HUB BOLTS
  • NISMO R-TUNE BRAKE PADS FRONT & REAR
INTERIOR / EXTERIOR
  • NISMO R-TUNE FRONT BUMPER
  • NISMO CARBON LOOK CENTRE PILLAR TRIM
  • NISMO CLEAR FRONT INDICATORS
  • NISMO CLEAR SIDE INDICATORS
  • NISMO “GT500” L.E.D TAIL LAMPS
  • NISMO GEAR KNOB
  • NISMO FLOOR MAT SET
  • NISMO METER SET – WHITE
  • NISMO M.F.D ( MULTI-FUNCTION DISPLAY) SPEC KIT VER.II
Plus, do the plates count? lol
And my daily R33 has;
Nismo LMGT-4's
Nismo Braided brake lines
Nismo Clutch slave cylinder
Nismo Super Coppermix single
Nismo radiator cap
That is cheating Joe.
You can't buy a Nismo promo car and claim nismo whorisim.
hahaha
Bahahaha sure I can, I would have had a list that long on the 33 if I had thrown the cash at that instead :yes:
Plus I harass you to sell me those rims EVERY time I see you lol
Nismo...
LM-GT4 wheels
Clear indicators (I think they are Nismo?)
600cc injectors
Competition Spec Coppermix twin plate clutch (awesome clutch thanks to Stevo-O).
Oil separator can
Fuel pump.
Fuel regulator... and
'Hoodie' jumper
Omori factory shirt :-)
nismo lmgt4
nismo dark indicators
nismo exhaust
nismo cluster
nismo floor mats
nismo ti gearknob
nismo fuel pump
nismo power brace
nismo timing belt
.......how is it all?....GREAT, except the exhaust which looks like a55 (and not the good kind)
still yum ^^
...and the thing about Nismo items (except for your exhaust if it has a 90 degree bend in it), is that you can take them off > sell them easily
Terry I put the exhaust up for sale with some other bits and pieces last week. Many expressions of interest for everything and few pieces sold, but the exhaust :/ Its the discontinued oval-tipped one...The guys over on the UK forums were selling them used for $1400 :O
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
