You just buy them, no exchange needed. Guess they go round stealing them off old wrecks and old Oem stock!
Can't work out why one side of the bar is braced extra, but guess they know.
They're still in production. They wouldn't use used parts.
All parts genuine
Currently own:
Lmgt4 white 18x7.5 +30
Lmgt4 bronze 18x9 +22
Lmgt4 silver 18x9.5 +12
Black: still to collect 18x10.5 +15
Nismo design key uncut - 8 point
Nismo horn button
Nismo gt shift knobs rubber and titanium
Nismo r tune front bar fiberglass - s15
Nismo 740cc injectors x4
Nismo 555cc injectors x6
Nismo gt LSD pro tt model
Nismo floor mats 5 piece set
Nismo speedo 260km/hr
Nismo timing belt
Nismo main and conrod bearing sets
Nismo number plate surround
Nismo wheel nuts
Nismo valve caps
Nismo horns (came on s15 lol)
Nismo t shirts x3
Plus a few other bits
Sold:
2 of those horrible duracon gear knobs
Fuel filler cover that was junk
One set of lm gt3 in silver 17x7.5 17x8.5
Lost:
nismo lanyard
Nismo hat
Would like to buy
Lm gt4 in 19 inch 9.5 or 10.5 width
Nismo inlet manifold
Nismo outlet pipes in carbon from r34 clubman spec, surely they will produce these
Nismo suppercoppermix twin plate c spec
Nismo intercooler and hard pipes (just because)
Edited by Gts30t
Wish whoever left one spam, now my comment looks out of place and weird :/
Lol ^^
If I ever sell my GTR, I'd like to think that the Nismo key goes with it, as an uncut blank.
They're badges above and below the key. They're made by Nissan, but I can't find the Part#.
  • 1 month later...
  • 1 month later...
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
