Can't see where you're located but I asked NISMO about the seats and they told me that only a NISMO tech can install them. I guess they said that per warranty,etc.
I really wanted to do this but I'm set on removing and storing my seats so I install carbon seats
Just had a quick count on my r34 gtr, 26 items on there ranging from intercooler to oil cap to much to list and bore you with,I like those parts always a good fit and top quality, down side not so cheap .
Edited by EM1
I'll start at the front
Nismo intercooler
Nismo piping kit
Nismo plenum
Nismo air flow meters
Nismo air inlet pipe
Nismo air duct
Nismo timing belt
Nismo engine/gearbox mounts
Nismo oil pan baffle set
Nismo oil separator
Nismo fuel pump
Nismo super copper mix clutch
Nismo GT taillight set
Nismo smoked indicator set
Nismo multi function display/fitted from factory
Nismo oil cap / rad cap
Nismo floor mats
Nismo titanium shift knob
Nismo sway bar kit
Nismo s tune suspension
Nismo performance damper kit
Nismo latest ti strut brace
Nismo big operating cylinder
Nismo clutch hose
Nismo brake lines
Nismo carbon fibre blade
And that's it doing an engine build todate and most other parts are hks
Inj,oil pump pistons crank,I could just keep going should be running in the
next month.
Edited by EM1
I'm drooling over this thread
Only a small list at the moment but will be expanding on it (after reading this thread lol)
Nismo leather gear knob
Nismo clear front indicators
Nismo clear side indicators
Nismo car seat covers
Nismo LMGT4 rims (delivered just yesterday :D )
Nismo oil cap
Nismo radiator cap
Nismo fuel cap
On the cards
Nismo wheel nuts
Nismo air valve caps
Nismo floor mats
Nismo engine mounts
Nismo gearbox mounts
And whatever other Nismo stuff I can get my hands on :P
aiiight........ I will kick start this off
nismo racing radiator cap - (P/N:21430-RS012)
nengun-1221-02-nismo-clutch_pedal_bracke
nismo reinforced clutch pedal bracket for BNR32 (P/N:46550-RS585)
nismo white meter set for center console for BNR32 (sorry for the bad photo will have to take a better one)
nismo GT shift knob (titanium version) (P/N:32865-RN013)
nismo intake collector kit (P/N:24820-RN583)
nismo 320kph Speedometer (P/N:24820-RN583)
nismo Super Coppermix Twin Plate clutch (BNR32 94 - pull type) rated @ 640ps 9807N (P/N:3002B-RS599)
nismo Big operating slave cylinder for BNR32 - pull type (P/N:30620-RSR40)
nismo Racing release fork pivot (P/N:30537-RS581)
I have more but will post that later on ;)
  • Like 1
  • 4 weeks later...
  On 26/03/2014 at 1:42 AM, Gts30t said:
Was going thru some stuff and found my nismo key that has been cut but didnt work. Might see if a locksmith can smooth it up a bit and get it working...
* Was it copied off an existing key or off the key code sourced from computer?
* Try a spare blank first and cut that. If it works then use the Nismo key. The cheap copy can be a valet key for the boot. The Nismo one is too valuable to sacrifice of course.
Terry: looking at it I think the profile each side is not 100% aligned properly, it was cut from an original key. It should buff up ok and come back to that nismo bling we all know and love. I was just thinking how really old worn keys usually work well and maybe this one could be smoothed out and made a bit looser.
