  On 19/02/2016 at 4:51 AM, -S- said:
Relax flamin mongrel. I'm a nismo fan myself. I just haven't listed my nismo parts. Im just saying that gauge looks like a multi gauge and I would rather have the updated trust gauges.
I SAID
dude i was messing with you lol around $900 delivered is eye watering.
Perhaps you should start a thread titled 'Finding Nismo Equivalent' ? :P
  • Like 1
  On 19/02/2016 at 5:38 AM, Terry_GT-R34 said:
"...stupid expensive nismo kill switch lighter..."
So, it doesn't deserve colour - 'tis made to look anaemic!
...but I'm not going to sell it!
That pic is oh so gorgeous. .. can't wait to do something like that. .. [emoji5]
  • Like 1
Not exactly Nismo but plenty of articles on Nismo and pure GTR porn.
Some of my mint condition collection of GT-R magazines and other from issue 1 onwards.
You can not get the first 50-60 odd issues in back issues anymore so very very rare and guarantee you would hard pressed to find collection like this even in japan.
There are months of GTR fapping.
For right price I could be persuaded to part ways.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
