Badges...
We're all familiar with current badges/logos.
But does anyone here know when then these other badges/logos were operating or for what periods of time?
1)
2)
3)
4)
5)
I'm presuming correctly aren't I, that there must be some overlapping?
BNR32 enthusiasts. I have just found out that the Omori factory BNR32 inlet pipes are for install at omori only. I tried to order them and they would not sell. Even though I had about 8 thousand dollar parts order lol, so I will have some nice pics in a month or so :). They say NO!!!!! It is because of the customization that is needed to fit them. I guess they don't want shoddy jobs all over the world mis-representing their parts. This is kind of upsetting as I believe the carbon fiber pipes will be the same way once they are released. Which is what I originally wanted. So you are either stuck with stock customized twin turbo pipe, or go aftermarket and lose factory air box. Really disappointing. I think this is a new thing because people have bought them when visiting omori factory personally. They must have changed there minds for some reason. I really do like the look of the Trust air suction kit (which im sure sounds really good to). But I like that stock, nismo, look :( It's a sad sad day......but on the bright side....I got a 2k refund LOL. Maybe i'll just get some suspension arms or something instead.
Unless you ship your car to them for work to be done. Which would be totally awesome....but super expensive lol.
Edited by JTCC
  • Like 2
Thats a shame mate, i think with some of the really limited stuff they are getting tired of foreigners cleaning out their stock and having nothing left for their own customers.
You might be able to find a second hand set in the future so keep an eye out. If i see one ill let you know :)
  • Like 1
Yes thank you. At this point, if they release carbon intake pipes, I might just save up and ship the car over for engine overhaul and carbon intake pipes. But that would be in the future lol. If I'm going to ship a car to them, I might as well make the trip worth it.
I guess you missed the part where I said engine overhaul lol. Either S2 or just a final spec. Depends really on what it would cost and funds etc. My life style is pretty crazy lol. But there is plenty of things you can have done while its there. If the only way to get these parts, is by them only, then I'll do what I have to do. Custom Omori name plate in the engine bay would be a nice touch also. It's more than a hobby to me. But as far as intake goes, I wouldn't bother for the aluminum. If they come out with carbon pipes and the box, then I would take this idea a little more seriously.
Edited by JTCC
Actually though i saying that...
You avoid the taxes on the new parts if you ship your car in. If you are looking at buying that much worth of stuff, the tax you don't pay probably pays for the shipping.
ah yes I didn't even think of that. Not to mention the shipping of actual part from Japan to USA would have to be added in individual item prices to. So it would probably come close to the same. I know you can get engine overhaul anywhere. But I want a nismo motor(if possible). I basically have all the nismo bolt ons already available to public and GCG hi flowed -7s. I'm waiting till the engine starts to show fatigue though before thinking of crate motor or just general overhaul
Edited by JTCC
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
