Nice parts Anthony, how hard were the seat covers to fit. Im considering getting a set?
a royal pain in the ass to fit. After you get the hang of it it's ok.... but it took around 4 hours.. 3.5 of which was on the front 2. The rear seat was easy.
  • Like 1
Well got a little update. The omori factory bnr32 inlet pipes are available. Mine were delivered today, but I am still about 3 weeks to a month from returning home to see them :( I don't understand why nismo called my guy and said that they were for install only and had to cancel my first order. I think there had to be some kind of mix up in communication or something. So all is well BNR32 people. I will get some pics up when I return home!
Can anyone tell me anything about these shocks? Came out of my r32 gtr but i dont think they are the factory shocks are they? They look as old as the car though. Nismo part numbers 56110-rn585 and 56210-rn585. They are made by KYB.
I wouldn't mind any information about these too. Might get my wife to translate.
How did they perform, although after quite a few Kms, any shocks may require maintenance?
Resurrecting some old posts. But I was under my (new to me) R32 GTR and found the same shocks. Any info on these? I've only driven it around town, but seems to ride well. Haven't put my stress on them. Was planning out a suspension overhaul in near future and shocks/springs vs coilovers was obviously on the list. Wondering if this should affect that decision.
Does it comes with some nismo goodies inside?
Comes with a shoulder strap inside ! [emoji3] was originally looking at the gtr tool kit but gave up on that once i saw the price !
I have more than enough snap on tools to fill this bag
Woo #1000 post [emoji3]
  • Like 3
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
