Nice parts Anthony, how hard were the seat covers to fit. Im considering getting a set?
a royal pain in the ass to fit. After you get the hang of it it's ok.... but it took around 4 hours.. 3.5 of which was on the front 2. The rear seat was easy.
  • Like 1
Well got a little update. The omori factory bnr32 inlet pipes are available. Mine were delivered today, but I am still about 3 weeks to a month from returning home to see them :( I don't understand why nismo called my guy and said that they were for install only and had to cancel my first order. I think there had to be some kind of mix up in communication or something. So all is well BNR32 people. I will get some pics up when I return home!
Can anyone tell me anything about these shocks? Came out of my r32 gtr but i dont think they are the factory shocks are they? They look as old as the car though. Nismo part numbers 56110-rn585 and 56210-rn585. They are made by KYB.
I wouldn't mind any information about these too. Might get my wife to translate.
How did they perform, although after quite a few Kms, any shocks may require maintenance?
Resurrecting some old posts. But I was under my (new to me) R32 GTR and found the same shocks. Any info on these? I've only driven it around town, but seems to ride well. Haven't put my stress on them. Was planning out a suspension overhaul in near future and shocks/springs vs coilovers was obviously on the list. Wondering if this should affect that decision.
Does it comes with some nismo goodies inside?
Comes with a shoulder strap inside ! [emoji3] was originally looking at the gtr tool kit but gave up on that once i saw the price !
I have more than enough snap on tools to fill this bag
Woo #1000 post [emoji3]
  • Like 3
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
