I haven't had any scratches on my nismo wheel nuts yet (that I've noticed), but they probably havent been removed that many times.
I may have to take up Terry's recommendation too.
I also wanted black wheel nuts to contrast with my bronze LMGT4s, so I understand where you're coming from.
  • Like 2
This is how the Nismo wheel nuts look after about a dozen sets of removals and replacements. Swirls are yuk.
Accentuated in sunlight evidently.
I look after my 2nd set much better. No marks with the Rust-Oleum Peelcoat rubberised spray (into the socket).
  • Like 2
Can I play? Bought my coupe and this oil cap was on top of the redtop engine, brought it across to the rb25 when I dropped it in. A little damaged but cause nismo ill run it still!
Also I seen this sticker was available from Nissan a year or so ago, ordered it because it looked old school and cool. Tried re ordering one a few months ago when I seen Yahoo auctions had them listed at a silly price.. NLA now :( Wish I stashed a few away at a crazy price of about $15.
  • Like 2
Dont care so much about what it is but I would like to find the thingo that goes in place of the ash tray to fit it there.
May well be this:
http://www.hks-power.co.jp/en/product/electronics/boost/evc6-ir24/index.html
Edited by djr81
  • Like 1
Car that I have this time to introduce the
ultra-superb! 1993 Formula BNR32 Skyline GT-R 1 owner indoor storage, rain unused, real running 19,000 KM! OS Giken RB3.0KIT> 3037 Twin & OS Giken sequential 6 It will be the introduction of the fast vehicle.
Your car we also carried out, including all tuning and maintenance from normal in jewels and vehicle of the original run deuce-like production in Okayama Prefecture.
Although engine even if the distance did not have exactly the ride last year, has just been full overhaul Performed at the same time as the maintenance because it has passed a number of years, only two thousand KM after construction.
With regard to power, but speed is limited to about 650PS along with the legalization of the current exhaust relationship than the original specification, in the previous specification had been out about lightly 850PS boost 1.5.
Also torque measurement of Shashidai was has become a measurement can not shake off until 80Kgm.
In fact 1000PS over is also a specification that aim comfortably. In addition it also equipped with enough strength for that.
Introduction agency relationships and drives the base vehicle, the vehicle is also high degree of perfection, while high-level up to this point, such as cooling braking I think that it is a vehicle of the not much out with twice.
Tuning specifications associated with the production it also took immeasurably.
Anyone heard anything about new carbon parts for the r32? Apparently omori factory held a little get together focusing on the essentials of the circuit. supposedly show off new carbon parts for front of r32. Im hoping a carbon omori lip or something. The description was very vague like it's a surprise or something.
"In addition, carbon NEW parts be able to show off in front for BNR32! ?"
Unless "in front" means front of the shop lol. Could be translation issue, but I'm anxious to hear what is. Possibly the carbon inlet pipes and air box?
Edited by JTCC
Fujimura makes a carbon front lip for the BNR32 .
My nismo specific range from my current stash of GTR/Nissan literature collection.
Nismo Sports Resetting Menu & Nismo Sports Parts catalogue.
Nismo Street & Sports Parts Catalogue ('01), Altia/Nismo OWN catalogue, Nismo Street & Sports Parts Catalogue ('99)
Nismo Engine Tuning Menu. Left is 2003. Right is 2006.
Nismo Z-Tune sales brochure's including specs of all 4 variants of the Z-Tune
Nismo Engine Tuning Menu with 10 page price list for all packages and parts for BNR32, BCNR33 & BNR34. (Thanks Tim for allowing me to include this piece in my collection)
  • Like 7
I am Glad it went to a good home Raj. Very special collection, I think it deserves this also
  • Like 1
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
