  • 3 weeks later...
A sea turtle has been rescued in Thailand. After stomach lavage, it was revealed that the turtle had swallowed many coins which is why it was finding it difficult to stay buoyant enough to  breathe.
It has been named "OMSIN", which in Thai, means Piggybank. That's how I found OMSIN. :)
Backwards Bankpiggy  NISMO , lol
  • Like 1
Thought i had posted here but it appears not.... the Headrest on the interior has since been fixed as has the horn button been straightened haha, was a quick snap when instaling. Still restoring the foot rest.
IMG_20161125_1950473.thumb.jpg.af91a48005db5664669f7aa2184baa16.jpg1481531512845867067855.thumb.jpg.714c4564757a223cae19968ff997dbc9.jpgIMG_20161125_1949145.thumb.jpg.91fb13b939ab95afeca4db87d0e46e9b.jpg
  • Like 3
  • 4 weeks later...
received_10154670280817659.jpeg off topic ( people hear have a good keen eye ) so i have NO luck sourcing a part number or even finding one for sale for an OEM factory 1996 GT-R option full carbon fiber interior trim.
Been looking 3month mad for this now.
By far this must the the rarest item to come by and i want it. !
http://www.r33gt-r.com/p/nissan-oem-catalog-1996-r33-skyline.html?m=1
Image is the best as it gets.
Surely someone has seen one or have one, would be nice to get the spotlight on it. [emoji4]
  • Like 2
Did they only make r34 one? I cant seem to find them on the website for any model. I've been on the fence about one for the 32. I know attain makes one. Curious to see how nismo would design one if they made it. Your's looks pretty clean and tasteful.
Hey Ryan,
They make them for 32,33 and 34. Pics are a few pages back, there's been nothing officially posted by Nismo about them yet. Its like they don't want your money :)
Those brake guides look expensive, i better start saving...
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
